1. JohnnyRanz's Avatar
    Everytime I leave home, work, or school, my WiFi gets stuck on my previous WiFi connection. If I go from home to work, my phone will still show as connected to my home WiFi, and vice versa. I have to physically turn off the WiFi and turn it back on in order for it to reconnect. Anyone else have this problem?
    BTW I'm getting damn well fed up with this phone...
    11-27-2012 10:24 PM
  2. CountryDevil's Avatar
    I had the same issue and several other issues after the last maintenance release. I reluctantly did a hard reset and it fix a whole bunch of network issues I was having. Have you done a hard rest since the last release? If not, I suggest that you at least consider it and try it.
    11-27-2012 10:34 PM
  3. JohnnyRanz's Avatar
    How does a hard reset work? I'm not to sure how to do one either
    Sent from my EVO using Android Central Forums
    11-27-2012 11:03 PM
  4. JohnnyRanz's Avatar
    Now my girlfriend just told me she texted me and called and got my voicemail. Didn't get either. This phone is really pissing me off. Now my texts don't send I just got an unable to send message error when I have full service. Ugh!
    11-27-2012 11:19 PM
  5. JohnnyRanz's Avatar
    Annoyingness
    11-27-2012 11:22 PM
  1. Factory reset or Google backup keeping WiFi login info?
    By lazygroundhogs in forum Droid RAZR MAXX
    Last Post: 07-02-2012, 07:54 PM
  2. Is there a soft reset to get the wifi to work
    By JOHND67 in forum General Help and How To
    Last Post: 01-27-2012, 11:55 AM
  3. WiFi, Resets & Backup Assistant
    By angels728 in forum Verizon HTC Thunderbolt
    Last Post: 05-18-2011, 02:32 PM
  4. Hard reset, no data plan, will wifi be configurable?
    By sydseale in forum General Help and How To
    Last Post: 05-06-2011, 08:32 AM
  5. Wifi issue after reset
    By Crowfoot in forum HTC Droid Eris
    Last Post: 03-02-2010, 03:01 PM
