09-16-2014 10:45 AM
78 1234
tools
  1. NastyNeil's Avatar
    I forget exactly what you have to do to test the proximity sensor. I know it is ## something. Any help?
    12-14-2012 06:01 PM
  2. NastyNeil's Avatar
    Nevermind, it is *#*#DIAG#*#*
    12-14-2012 06:15 PM
  3. Mikey47's Avatar
    Nevermind, it is *#*#DIAD#*#*
    Actually it's *#*#DIAG#*#* (probably just silly autocorrect on your keyboard).
    12-14-2012 06:27 PM
  4. NastyNeil's Avatar
    Lol, damn autocorrect
    Sent from my EVO using Android Central Forums
    12-14-2012 06:38 PM
  5. dontspamtheman's Avatar
    I now have this problem after the update and it is awful. Phone is also heating up and draining battery at times now. Before the update I had horrible contact lag and paused dialing issues. My og evo was solid but this has been the biggest pos. I hate this phone. I am so over the non stop issues. Going to have to get a phone that works. This one is going on Craigslist.
    12-14-2012 09:04 PM
  6. dtreo's Avatar
    My solution: push the top on button & the screen magically appears.
    Your welcome.
    Love it when my smartphone gets dumber.
    12-14-2012 09:15 PM
  7. nightdesigns's Avatar
    This is a major issue. If I navigate away from the call screen while on a call, when I try to unlock the screen it immediately turns off. I can't do anything except a hard reboot. Can't end the call, touch a button, nada.
    12-15-2012 12:31 AM
  8. Cattails_r_Edible's Avatar
    I just tried this, I was on a call and hit the home key, my notification turned green and I talked some more as I opened my calendar, when I closed the calender, I pulled down the notification and press the phone call and it went back to the dialer, just as it should!
    SENT FROM MY JELLYBEAN EATING EVO!
    12-15-2012 12:57 AM
  9. Andras's Avatar
    Lucky you. It sucks having this issue again, especially since the phone launched with the issue and it was later fixed. Hopefully it won't take long to fix it again.
    12-15-2012 02:08 AM
  10. 321contak's Avatar
    After factory reset, Proximity sensor is still buggy but working ONLY if in a bright enough area/room. The sensor on JB update is set to not work well in low light settings. A simple fix HTC can release hopefully quick. Very annoying.
    12-15-2012 01:23 PM
  11. mawilson82's Avatar
    Yea if it is low light it won't come back until you face the phone towards a brighter light.
    So don't use your phone in the dark. lol
    12-15-2012 04:33 PM
  12. glenninduluth's Avatar
    After first doing the JB update, I had no problems at all with the phone. Then, today I started having the proximity sensor issue. I kept thinking over and over if I had changed any settings that could be causing this. Then I remembered something: Late last night I switched from using my very thin & simple case to a more heavy duty case that has a cut out for the sensor. So, I made a call with the heavy duty case on and the issue with the sensor was still there (I don't use a screen protector). Then, without hanging up the call, I took that case off and the sensor now works! I have repeated this several times now. Heavy duty case with a sensor cut out on the phone, proximity sensor doesn't work. Simple case that doesn't need a cut out (or no case at all) and it works fine. Now I don't know if this is just my phone, but for those having the proximity sensor issues might I suggest you try it with and without a case or screen protector to see if this fixes the problem.
    12-15-2012 05:21 PM
  13. Andras's Avatar
    Naw my phone is naked
    12-15-2012 05:33 PM
  14. othersteve's Avatar
    Thanks but it's long been known that this is an issue independent of any screen protectors or cases. It's a hardware issue that very likely requires software correction to make it palatable.
    What's amazing is how simple the coding fix probably actually is in practice. Hypothetically, considering that this issue only exists in low light, it's probably something as easy as restricting screen state changes to instances where a certain gyro/accelerometer measurement coincides with the luminosity measurement change. That is, making sure that you are using some sort of two-factor verification that the phone is actually being moved away from the ear as opposed to simply relying on what now has proven to be a seriously $#!Tty proximity sensor.
    Regardless of the fix, what's truly stunning is that after many months of this problem obviously being reported, HTC still has yet to have definitively provided any sort of mitigation or workaround to those affected. It is yet another reason why this will absolutely be my final HTC device, sad as I am to say it. I do not see their company turning around anytime soon.
    Just my $.02.
    12-15-2012 06:13 PM
  15. koam's Avatar
    Screen goes black as soon as I press "CALL" or answer a call. It's a mess.
    12-17-2012 05:44 PM
  16. axllebeer's Avatar
    Yep same here.
    But I am able to toggle it off and on with the lock button.
    12-17-2012 06:43 PM
  17. xcrico's Avatar
    Same issue here. Got fixed in a previous update and now is back again... So frustrating...
    12-18-2012 02:46 AM
  18. JManekia's Avatar
    Count me in as well with proximity sensor issues. I've hard booted my phone, did a factory reset, ran the P Sensor test and cleaned my phone screen and it still wont work.
    12-18-2012 08:40 AM
  19. Andras's Avatar
    Same thing here.
    I've been in contact with HTC since the update regarding this and have done their first level steps to try to resolve the issue. Right now my ticket has been sent to their escalations department and I should receive a phone call from them in a couple days. I'll report back here after that and let you guys know the outcome.
    321contak and Kinolay like this.
    12-18-2012 08:57 AM
  20. nathy321's Avatar
    I am having this exact same issue, it is soooo frustrating. Also the touchscreen is less responsive, I dont know what to do it happens on every call
    12-18-2012 12:57 PM
  21. delthor7's Avatar
    Same thing here.
    I did the same thing a day after the update. Hope they push out an update soon.
    Sent from my EVO LTE
    321contak likes this.
    12-18-2012 12:58 PM
  22. errbin's Avatar
    something I ran into to day the sensor works when I'm in a lot of light... but in dim or dark areas it doesn't work
    can someone else test their phones
    sent from a EVO that survived a Apple attack... thug life
    12-18-2012 06:23 PM
  23. Kinolay's Avatar
    I'm having the same problem. It either goes black as soo. As I hit "Call" or it doesn't go black at all when I raise it to my face.
    12-18-2012 09:05 PM
  24. TonyLibations's Avatar
    Just for the record: I'm a day 1 owner who never had this problem until after the JB update. Earlier in the year when others were dealing with the issue, I was one of the lucky few that weren't.
    Sent from my EVO L(a)TE using Android Central Forums.
    12-18-2012 09:17 PM
  25. Darth Mo's Avatar
    This one seems to be a problem that everyone is having post JB. It's definitely broken.
    12-18-2012 09:26 PM
78 1234
  1. Replies: 28
    Last Post: 04-18-2016, 12:37 AM
  2. Screen blinks on and off during phone call
    By rreich49 in forum Verizon Galaxy Nexus
    Last Post: 08-30-2013, 08:01 AM
  3. Screen Keeps Turning On During Phone Calls
    By Applesapples in forum T-Mobile Galaxy S 4G
    Last Post: 07-24-2012, 09:06 AM
  4. Clarity problem with earpiece during phone calls.
    By daniel-k in forum Verizon HTC Rezound
    Last Post: 02-07-2012, 07:38 PM
  5. Screen not coming on during phone call
    By mskaplan in forum Motorola Droid
    Last Post: 11-19-2009, 10:49 PM
