Page 1 of 4 1234 LastLast
Results 1 to 25 of 76
Like Tree8Likes
    321contak's Avatar
    Posts
    Global Posts
    91 Global Posts
    Default Proximity sensor problem during phone call back on Jellybean update
    I am experiencing the proximity sensor issue while on a phone call since the new jb update. This issue was solved on the previous update. Is anyone else having this issue happening again?
    Thanks community
  2. #2
    ECHO-313's Avatar
    Posts
    Global Posts
    28 Global Posts
    Default Re: Proximity sensor problem during phone call back on Jellybean update
    I've got the same problem. Also the volume will not work when I'm on a call.
    Sent from my EVO using Android Central Forums
  3. #3
    Same problems here too.
  4. #4
    Mine works fine! Try a simulated battery pull!
    Sent from my EVO using Tapatalk 2
    321contak's Avatar
    Posts
    Global Posts
    91 Global Posts
    Simulated battery pull instructions please. Thanks
  6. #6
    Quote Originally Posted by 321contak View Post
    Thanks community
    Same here
  7. #7
    Press and hold the power button for 10 seconds for a battery pull!
    Thanked by 2:
    AetherJones likes this.
  8. #8
    Quote Originally Posted by Cattails_r_Edible View Post
    Did the simulated battery pull. Still didn't fix the proximity sensor issue
  9. #9
    Did sim battery pulls...full hard reboots waiting a couple minutes time before restart, even factory reset it...it's still there. This is the first update that has actually made my phone worse. Guess my luck ran out
  10. #10
    Try a factory reset!
  11. Thread Author  Thread Author    #11
    321contak's Avatar
    Posts
    Global Posts
    91 Global Posts
    Will Factory reset wipe phone out? Have to reinstall everything?
  12. #12
    Yes it will!
  13. #13
    crxssi's Avatar
    Linux: The power beneath
    Posts
    Global Posts
    1,823 Global Posts
    Just tested mine- no problem with proximity sensor on call. Bring to face and screen turns off, pull away from face, screen returns. Tried it several times.
    Click "Thanks" and/or "Like" button on posts where someone helped you or you liked the posting. Provide HTC feedback here: http://www.htc.com/www/contact/email
    dyphx likes this.
  14. #14
    Yeah mine isn't working either... It used to work just fine, and now it stays on or off... Ahhhh!!
  15. #15
    Yes same problem here. Not sure what else to do about it.
    Don't ya hate all the waiting and then, a critical problem like this. A phone that is failing within the phone app.
    Update Jan 23rd:
    And for no apparent reason, my sensor is working normally again. Started a little over 24 hrs ago so I waited at least a day before posting this. I didn't do anything. Same case, never used a screen protector, I clean my screen about 2 X's a day.
  16. #16
    I had an app that I paid for that let you wave your hand in front of it using the proximity sensor to turn the phone off...that's broke too now.
  17. #17
    My prox sensor is broken too, along with my volume control while I'm on a call. It's not too big of an inconvenience for me because I mostly call using Bluetooth. Hopefully a fix comes out soon. My wifes phones has no issues after the update.
  18. #18
    If this is like the first time the proximity sensor was messed up, it was a combo of the a software bug and your screen protector. I haven;t tried it yet but taking the screen protector off should fix this. It did before.
    I was so looking forward to this update and it's crap like this that ruins it. I can't even use my Google Voice to listen to voicemails correctly because of the stupid proximity issues.
  19. Thread Author  Thread Author    #19
    321contak's Avatar
    Posts
    Global Posts
    91 Global Posts
    No screen protector being used on my phone. Definitely software issue. It was fixed and no problems on previous update.
  20. #20
    I just noticed when I went to listen to a voicemail the screen shut off & I wouldn't come back unless I hit 'home'. I turned on speakerphone & now it seems to stay on.
    Any chance its related to the proximity sensor?
  21. #21
    I'm experiencing that same issue. Also proximity sure doesn't work like it used to. Way to fix some problems while creating new ones, HTC.
  22. #22
    Quote Originally Posted by Eclectech View Post
    I'm surprised that they recreated an issue they already fixed. It's like as if some people got the old coding for the proximity sensor.
  23. #23
    It is so ridiculous that it's even possible for this to occur within a company so well-acquainted with software development.
    FIX THIS PROBLEM HTC
  24. #24
    Quote Originally Posted by Andras View Post
    Its called a regression and happens all the time in software development. They must just not have a test case that covers this (although) they should.
    However, I would if the real root cause isn't hardware given that lots of people don't have that issue. The proximity sensor shouldn't be related to any other apps that you might have loaded.
  25. #25
    My solution: push the top on button & the screen magically appears.
    Your welcome.
    crxssi likes this.
  1. Replies: 9
    Last Post: 05-16-2013, 07:26 AM
  2. Screen Keeps Turning On During Phone Calls
    By Applesapples in forum T-Mobile Galaxy S 4G
    Last Post: 07-24-2012, 08:06 AM
  3. Screen blinks on and off during phone call
    By rreich49 in forum Verizon Galaxy Nexus
    Last Post: 06-24-2012, 11:49 AM
  4. Clarity problem with earpiece during phone calls.
    By daniel-k in forum Verizon HTC Rezound
    Last Post: 02-07-2012, 06:38 PM
  5. Screen not coming on during phone call
    By mskaplan in forum Motorola Droid
    Last Post: 11-19-2009, 09:49 PM
