Results 1 to 3 of 3
    Default Power Saver on JB
    Who is using it and who isn't, and do you notice a difference either way. I have finally found the right settings to get what I need out of the phone in a day's use. The settings do not include using power saver. Has anyone seen anything positive or negative to using power saver? Thanks.
  2. #2
    crxssi's Avatar
    Linux: The power beneath
    Posts
    Global Posts
    1,823 Global Posts
    Default Re: Power Saver on JB
    Quote Originally Posted by NastyNeil View Post
    Battery after JB
    One negative thing about it is the damn permanent notification that is extremely irritating. Thanks, HTC, for cluttering our notifications with something SO FREAKING IMPORTANT [NOT] and giving us NO WAY TO NOT LOOK AT IT (yes, this pisses me off).
    I personally have no interest in the "Power Saver" because HTC doesn't describe exactly what it does and I detest "settings" and "helper" systems that go behind my back doing secret things to "help" me. I know how to save and conserve battery life with traditional settings. I have no objection to them including some semi "smart" thing for people who don't, I just don't want to be forced to use it (thankfully not the case with this) or forced to LOOK AT IT every day when I have it turned off.
    Click "Thanks" and/or "Like" button on posts where someone helped you or you liked the posting. Provide HTC feedback here: http://www.htc.com/www/contact/email
  3. #3
    Ok, my battery life has been awful since update, so my first day I tried using Power Saver. It dims the screen, and turns off haptic feedbck I know, but other than that... didn't really notice any other difference. It slowed the power drain on my device, but not by enough to make me want to continually use it.
    And for reference I spent about 2 hours listening to Audible and Podkicker and 3 hours doing nothing with my device the power dropped to 71 percent. I used to be able to hover around 85-86 percent after the same amount of time. I used to listen about 5 hours at a time, but this phone would probably die now. It dropped 1 percent every few minutes doing nothing. Power Saver extended the time to about 10 minutes, but that's all.
  1. MyTouch 3G Slide Won't Power Back On
    By tricia_110407 in forum myTouch 3G Slide
    Last Post: 09-24-2012, 02:27 PM
  2. Battery pull vs power off/on
    By gbororats in forum Motorola Droid X
    Last Post: 06-28-2011, 11:23 PM
  3. Power Saver and Background Data
    By Doom4life in forum General Help and How To
    Last Post: 05-20-2011, 11:20 PM
  4. Xoom Power Saver Mode?
    By MJBarnes in forum Motorola Xoom
    Last Post: 03-01-2011, 05:02 PM
  5. Power controls on the slide down screen
    By rustypixel in forum Verizon Fascinate
    Last Post: 02-20-2011, 05:42 PM
