Results 1 to 7 of 7
    GOOFKC's Avatar
    Posts
    Global Posts
    10 Global Posts
    ROM
    Stock
    Question Notification Bar At Top Of Home Screen Will Not Swipe Down
    Anyone ever hear of that? It is on a buddies phone. Mine works fine. It happened pre jb update and the update did not change it. Thanks for any suggestions you can give.
    Chris
  2. #2
    BigDinCA's Avatar
    Posts
    ROM
    Stock
    Default Re: Notification Bar At Top Of Home Screen Will Not Swipe Down
    The top of the digitizer may be failing, if it hasn't changed with the update. My wife's old GS2 had a similar issue along the bottom. Have him try to rotate the home screens by swiping across at the very top. Also, if he just taps and holds the time at the upper right corner of the screen, it should expand the notification bar by a couple of rows, but it isn't the same as the full pull-down. See if that works.
    Thanked by:
    GOOFKC
    GOOFKC's Avatar
    Posts
    Global Posts
    10 Global Posts
    ROM
    Stock
    That does not work either. Thanks for the suggestion. I told him to take it to Sprint to get repaired. Just glad it is not mine. Knock on wood...
  4. #4
    Tell your friend take the phone to a Sprint repair center because this is a hardware issue. I started having that same problem in Sept. did a couple of factory resets and it would temporarily fix it. I installed NOVA Launcher so I could use the gesture options to open the notification bar but last week the phone started droving me nuts cause the screen would stop responding at random times... Usually at the same times the notificiation bar would not open. The tech guy at the Sprint store said that he had to replace the screen because it was bad. My notification bar is working fine now.
    Here 's a post in another forum about the notification bar problem.
  5. #5
    Quote Originally Posted by csawyerkc View Post
    Chris
    It's definitely a hardware issue. I have been dealing with the same issue for about 6 months now. When I try to swipe down to bring up the notification bar I get absolutely no feedback . If I give it a smack with my palm near the top corners I can often times get it to start working again. However, it's usually short lived.
    Tell your friend to dial *#*#DIAG#*#* from the dialer. Tap "Accept" if it takes you to a white screen. This should take you to a black screen with 2 columns of tests that you can perform. Look for "Line Drawing Test" in the first column and select it. Then tap the "Run" button. Start drawing with your finger. If his problem is like mine, he will be able to draw everywhere on the phone except for the very top 1/4" or so. Like BigDinCA said, I'm pretty sure the digitizer is failing. Maybe I'll make it to the store before mine completely goes kaput.
  6. #6
    nikiva101's Avatar
    Posts
    Global Posts
    38 Global Posts
    Yep take it in for repair, mine did the same thing...they replaced the phone
    Sent from my EVO using Android Central Forums
  7. #7
    Jim Duff's Avatar
    Posts
    Global Posts
    17 Global Posts
    I had the same problem, got it replaced eventually under insurance for no charge. Off and on, I also had a problem with one row of the phone dialer not responding, and someone on here months ago diagnosed it (correctly) as a failing digitizer. Good luck getting it replaced!
  1. How can I change icons at bottom of home screen?
    By walkingrock in forum Verizon Galaxy S3
    Last Post: 01-18-2013, 03:53 PM
  2. Multiple (18) arrows at the top of the screen in portrait mode
    By nunya.binuss in forum Google Nexus 7 Tablet
    Last Post: 10-28-2012, 10:47 AM
  3. Replies: 19
    Last Post: 09-30-2012, 08:46 PM
  4. 3G/4G disappearing at top of screen
    By astella in forum Droid Bionic
    Last Post: 11-09-2011, 12:50 PM
  5. Replies: 10
    Last Post: 10-06-2010, 02:10 PM
