Is anybody else noticing poor or poorer signal with the PRL 25010?
What ever the previous PRL was it seemed to work well. Sometime this week my service updated with 25010 and i started to notice lower signal in areas that i have always had full signal.
Then on 3 occasions now i have had text messages come all at once..
Example, this morning 11 messages came in all at once. This is bad because where i live is always full bars / great service. For the past few days its been 1 to 3 bars..
Another example. At my office, i get 4G LTE half bars, its been hovering at 1 bar. Then i got an email from someone trying to call me and it goes straight to voice mail. So i called my self using a differnt phone and sure enough.. multiple times it went to voice mail. Power cycling the phone fixed the issue of calls not going thru but i still have what seems to be poorer recieve signal strength.
I did check the back cover and verify its on tight.
Also my data speeds seem slower, on 3G and LTE.. but i would expect this with lower signal anyway, so the two should go hand in hand..
