Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Mikey47
    Default Battery drain from maps
    Just started seeing a spike in battery usage by maps. Any ideas why?
    Sent from my EVO using Android Central Forums
  2. #2
    Default Re: Battery drain from maps
    Quote Originally Posted by scratchfwb View Post
    I can't quite remember, and someone correct me if I'm wrong, but I think crxssi has a post about this somewhere...
    scratchfwb, if you don't get my drift, there are TONS of posts around here about this. crxssi is leading the charge against location history and Google spy. I let him repeat his normal refrain.
    So Cold likes this.
    I thought I saw something a few weeks ago but couldn't remember if it was in the battery life thread or the problem thread... I was using Google Now but didn't have a problem til the last two days...
    Damn location history WAS on again. Does it default to that after a reboot?
  5. #5
    It's not supposed to, but that doesn't mean something else didn't happen to cause it to reset. I find, even with location history off, and Google now off, that maps is still always using 20% of my battery.
    Thanked by:
    bc2k
  6. #6
    Default
    Quote Originally Posted by Mikey47 View Post
    Try un checking report from this device. It's made a huge difference for me.
  7. #7
    Quote Originally Posted by Andras View Post
    Yep, been unchecked for quite a while.
  8. #8
    tivoboy's Avatar
    Posts
    Global Posts
    138 Global Posts
    What technically DOES report from device do?
    Thanked by:
  1. Battery drained from 95% to 14% overnight!
    By saintforlife in forum AT&T Galaxy S3
    Last Post: 03-27-2013, 06:38 PM
  2. Anyone notice huge battery drain from line app?
    By hawaiijedi in forum Verizon Galaxy S3
    Last Post: 12-08-2012, 08:29 AM
  3. Battery drain from calls
    By beavertailslap in forum Droid RAZR MAXX
    Last Post: 09-07-2012, 02:52 PM
  4. Battery Drain from Phone Calls
    By jtl in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 10-27-2011, 12:56 PM
  5. Maps 5.8 - high battery drain
    By mrg666 in forum Android Applications
    Last Post: 08-01-2011, 08:38 PM
