Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By TheGloper
  • 1 Post By axllebeer
    Default FM Radio not working after JB?
    My factory HTC fm radio worked fine before JB, but now the icon is still there and when I try to open it, it says application not installed. When I go into settings then apps I get what it shows in the pic. Anyone else's not work?
    Sent from my EVO using Android Central Forums
    Attached Thumbnails Attached Thumbnails FM Radio not working after JB?-uploadfromtaptalk1358184337723.jpg
  2. #2
    Default Re: FM Radio not working after JB?
    MIne works for what it's worth.
  3. #3
    top magoo's Avatar
    Posts
    ROM
    Stock
    mine works too... i'm listening to it now.
  4. #4
    I Had The Same Problem When I Updated. The Shortcut Was Just Bad. I Deleted It From My Home Screen And ReAdded It From My App Drawer AnD It Was Fixed. Sorry For The Odd Caps, Not Sure What's Going On.
    TonyLibations likes this.
  5. #5
    Quote Originally Posted by TheGloper View Post
    It adds dramatic effect! Lol.
    Sent from my EVO L(a)TE using Android Central Forums.
    Tony Anderson
    Social Media Manager
    Jacksonville, FL
    @TonyLibations <---For the Twitterin'
  6. #6
    I still have the widget for it, but the app itself is gone. The widget won't work either. Can I download it again somehow? Tried to use it this morning to no avail.
  7. #7
    Here ya go.
    FM Radio APK:
    FM Radio Widget APK:
    Click 'Thanks' if that helped and enjoy!
    Tony Anderson
    Jacksonville, FL
    Thanked by 2:
  8. #8
    bigrey81's Avatar
    Posts
    ROM
    4.1.2 and 4.2 stock
    Clear cache partition the reset phone
    - - - Updated - - -
  9. #9
    Quote Originally Posted by TonyLibations View Post
    Here ya go.
    FM Radio APK:
    I really appreciate it. However every time I try to install them they both fail. Any ideas on how I can get it to finish the install?
    Update: for some reason it's disabled. And I see no option to re-enable it.
    Attached Thumbnails Attached Thumbnails FM Radio not working after JB?-image.jpg
  10. #10
    bigrey81's Avatar
    Posts
    ROM
    4.1.2 and 4.2 stock
    Quote Originally Posted by axllebeer View Post
    Did this function move since Jelly Bean because I can't seem to fine it anymore.
    To clear cache partition Press and hold the volume up then tap the power button, The screen should change to have more options pop up like reboot system now, wipe cache partition, and wipe data/factory reset, when you see these go down and select wipe cache partition then hit power to select.
    5. Go down to reboot phone with the volume down keys and then tap power to select.
    your phone is going to power off then start up again, Hopefully this helps, it doesnt remove personal data so your items on the device will be ok. Then to reset phone go to menu then setting go down to back up and reset and hit reset
    Thanked by:
  11. #11
    I have the same issue. Any help would be cool.
  1. Wi-Fi Tether Not Working After JB Update
    By eatsleepdrivesc in forum Sprint Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 05-03-2013, 01:17 AM
  2. engadget app not working after JB update
    By choclab1 in forum HTC EVO 4G LTE
    Last Post: 12-18-2012, 07:19 AM
  3. FM Radio Not Working
    By johndelk408 in forum HTC EVO 4G
    Last Post: 08-28-2010, 06:09 AM
  4. ESPN Radio App not working after Froyo update
    By stevied3 in forum Android Applications
    Last Post: 08-12-2010, 04:27 PM
  5. boot screen not working after installing Froyo Kangerade V1.0
    By jrickman in forum General Help and How To
    Last Post: 06-20-2010, 12:11 PM
