- 02-04-2013, 05:47 PM
Thread Author #1
- 02-12-2013, 12:29 AM #2
Re: EvoG LTE stuck at 99 percent charge
could be related to whatever programs are running in the background, but you may also want to google bump charging... it is when you charge as much as it will take it off charger then put back on charger till it stops, then turn off phone and charge again... Most phones wont let the batteries truly get over 95 to 98% regardless of what it says it is at.
- 02-12-2013, 12:57 AM #3
This is exactly right. Bump charging normally the workaround to seeing a full 100% when its stuck at anywhere above 95%.
Its not a bug or hardware related issue its just the way the device and battery work together to protect itself from overcharging which in itself is hard to do with today's batteries.
:: Getting Started with Android :: Forum Rules :: General Help and How To ::
» » » The All New Android Central App « « «
- 02-12-2013, 05:23 PM #4
Droid 4 Won't Charge, Stuck at 0%
By techtoaster in forum Motorola Droid 4Replies: 3Last Post: 12-09-2012, 12:59 AM -
Charge stuck at Samsung screen
By paxil in forum Verizon Droid ChargeReplies: 1Last Post: 09-30-2012, 03:09 PM -
Battery charge at 99%
By swkwong in forum Samsung Galaxy Tab 7.0 PlusReplies: 4Last Post: 08-17-2012, 09:10 PM -
Stuck at 99%
By johnnyshinta in forum Verizon HTC RezoundReplies: 13Last Post: 12-15-2011, 07:12 PM -
Stuck at white boot screen and home button not functioning
By wkj in forum HTC Hero Rooting, ROMs, and HacksReplies: 5Last Post: 06-18-2010, 06:40 AM
Reply
