1. elshagon's Avatar
    Just got a replacement Evo and after a few hours it began vibrating non-stop. There's no battery to pull and shutting it down didn't get it to stop either. The only way I was able to get it to stop was removing the back cover and locating a small pin next to the camera lens which spins while its vibrating. Pressing down on it gets it to stop, but once I put the cover on it begins vibrating immediately. Anyone heard of this problem, any easy fixes?
    09-07-2013 09:31 AM
  2. Mikey47's Avatar
    Did you try the simulated battery pull? Hold down on the power button for 20 - 30 seconds and let it restart.
    Have you tried a factory reset?
    09-07-2013 10:43 AM
  3. elshagon's Avatar
    Yeah it still continues when doing the simulated battery pull. I will try the factory reset
    edit: I tried the factory reset and it continued to vibrate during the reset and afterwards
    09-07-2013 11:39 AM
  4. riskybzns's Avatar
    The phone will reset long before 20 seconds.
    TonyLibations likes this.
    09-07-2013 12:22 PM
  5. oehrensperger's Avatar
    Sounds like a hardware defect to me. Can you return it for another replacement? Seems to me you have every right to get another one.
    Sent from my 2012 EVO via Android Central App
    09-07-2013 01:23 PM
  6. platanaso625's Avatar
    Had the same issue. Took it to sprint and they gave me another one.
    qxr likes this.
    09-09-2013 08:12 AM
  1. S Health Galaxy S4 Update Problem
    By guillaume133 in forum General News & Discussion
    Last Post: 08-01-2015, 06:40 PM
  2. Samsung Galaxy S4 SD Card Problem
    By KevroniCoal in forum Sprint Samsung Galaxy S4
    Last Post: 09-29-2014, 02:11 PM
  3. Homescreen Launcher problems
    By Spencer Owen in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-25-2014, 10:21 AM
  4. P5113 problem with usb connection in windows.
    By guitarplayer06 in forum Samsung Galaxy Tab 2 10.1
    Last Post: 11-14-2013, 08:20 PM
  5. problem with viber samsung pocket
    By Amr Dowidar in forum Android Apps
    Last Post: 09-07-2013, 07:40 AM
