Results 1 to 7 of 7
    elshagon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default 4.3 Problems - Airave?
    I've had the following problems since updating to 4.3:
    1. Unable to send or receive SMS texts
    2. Apps crashing and losing Wallpaper when connected to the pc and choosing "disk drive"
    The texting is the big thing for right now. I have google voice and perhaps that's the issue? It never was before. This will drive me crazy until figured out.
  2. #2
    VidJunky's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: 4.3 Problems
    If you develop bugs after a major update it is usually advisable to do a factory reset. Sometimes they work themselves out but a FR is the fastest and most reliable way to cure them.
    What to expect doing a factory reset:
    You shouldn't loose any of your pictures, vids, or music saved on the SD partition of your memory. What you will loose is all of your log in information for email, games, and apps that require a user name and/password. Your apps themselves are saved at the Play Store under your profile and once you sign in they should be there waiting for you. You will loose your screen layouts and your settings will revert back to factory. Your contacts will be saved, provided you've you haven't added any since you last backed them up or do a manual backup prior to your reset, through your Google account, Big Red's backup assistant, or your SIM card just depending on where you've saved them.
    Insurance:
    There are several backup apps at the Play Store. MyBackUp Pro is one that claims to save your settings and screen layout as well as your SMS and MMS conversations. It's a paid app but they offer a trial that should be enough to get you through one factory reset. However there are others so look there if you want a bit more insurance against loosing data.
    elshagon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tried the factory reset. Still no texting ability. All my texts say "pending"
    elshagon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So I turned on SMS in Hangouts, and can't get SMS to send or receive with Hangouts either. Any other suggestions in settings to try?
    *** Update: I've discovered that when I turned the airave off in the house I get my SMS texts back. I've never had a problem with the airave stopping texts in the past. Anyone else have an airave with the new update?
    jose0819 likes this.
  5. #5
    mfreeland's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by elshagon View Post
    My airwave is working fine with my updated phone. Before I was occasionally having connection issues when the phone was on the dreaded ch 476....
  6. #6
    kluecke's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having issues since the 4.3 update with my Airave: I can make and send texts fine when on the Airave, but nothing comes in to me. Callers get routed directly to my VM. Texts just never make it. I've reset the Airave, reset the phone, and today even reinstalled the 4.3 RUU. I was so fed up with this that I tried to reinstall the 4.1 RUU from HTC's site, but it wouldn't take. Even with the fresh 4.3, nothing comes in to me. Any help?
    Kevin
    elshagon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This thread (click here) helped me solve the problem.
  1. Anyone have this problem?
    By Pasco08 in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 03-13-2014, 01:23 PM
  2. memory problem
    By Weng Omaps in forum Android 2.3 Gingerbread
    Last Post: 02-19-2014, 03:51 PM
  3. Having problem with Hands Free mode and bluetooth...
    By restockton in forum Sprint Galaxy S3
    Last Post: 02-19-2014, 10:39 AM
  4. Having problems dl pictures via email or receiving them via text
    By Beth Clarke in forum General Help and How To
    Last Post: 02-19-2014, 12:25 AM
  5. Charging issues- Clearing Cache re leaved problem for only 8 days.
    By kelleygirlmma in forum Samsung Galaxy Tab
    Last Post: 02-18-2014, 09:31 PM
