Results 1 to 9 of 9
    Default Battery Issues with deck
    I am flashed deck 1.3 and been using it for few days. I noticed that even though I am using the seideo extended battery , I am only 4 hrs battery life .
    Dont know whats causing such low battery life , did anyone noticed the same thing and what did they tried to fix it.
  2. #2
    dumpedduce's Avatar
    Posts
    ROM
    Arctic Hd
    Default
    Never had a problem. Try flashing a new kernel. You can also try the build before to see if that helps it.
    DumpedDuce Approves This Message
    Default Re: Battery Issues with deck
    Flashing a different kernel will not effect ROM in any way right.
    I used to have random reboot issues with decks version before this one.
  4. #4
    dumpedduce's Avatar
    Posts
    ROM
    Arctic Hd
    Default
    Quote Originally Posted by carguy10 View Post
    Nope won't change the rom what so ever.
  5. #5
    HalizDad's Avatar
    Posts
    ROM
    Stock for once.
    Default
    Check your charger or battery. To discharge a 3500mah battery in 4hrs it would be hot as hell. I get 2 days out of mine with moderate use.
    Sent from one of my gadgets
    Treo650 > Pre > Hero > Evo4G > SGS2 > GNex > SGS3.<--seriously great phone
  6. #6
    bw75's Avatar
    Posts
    ROM
    Flashoholic
    Default
    I tend to always go back to deck 1.3 with Tiamat 3.3.7+sbc when I want an AOSP instead of Sense ROM. If you flash it and set minimum to 128 and max to 499 you should get very good time on the battery.
    Sent from my PC36100 using Tapatalk
    Current device: S-OFF White HTC EVO 4G LTE Rom: MeanROM_ICS_4.9 Kernel: 3.0.8
  7. #7
    bw75's Avatar
    Posts
    ROM
    Flashoholic
    Default
    Oh, and calibrate your battery after you flash a Rom. Charge to 100% then calibrate.
  8. #8
    eldub1's Avatar
    Posts
    ROM
    Team Venom v1.2
    Food for thought. Wipe the battery stats in the recovery.
  9. #9
    bluebandit97's Avatar
    Posts
    Global Posts
    74 Global Posts
    ROM
    Stock 2.3.3
    ive had similar battery issues in the past with decks... but mine are more sporadic. Every so often (maybe once every 2-3 weeks) i'll take my phone off the charger, then maybe not even 10 mins later my battery is down to around 50-55%. It happens so randomly and infrequently, that i just plug it back in to charge again and problem solved. Im using a Tiamat kernal with decks 1.3e.
