12-13-2011 06:55 AM
87 1234
tools
  1. rocklee99's Avatar
    sorry for multiple questions, but on the kernel post, theres a bunch of links, "flashable zip normal voltage, low voltage, 2.1 eclair, and then flashable zip 4g and wifi use with custom kernel, im confused on which one to pick (im on 2.1 eclair) and i want all feature (4g, wifi, and camera) to work
    07-29-2010 12:20 AM
  2. pingpongboss's Avatar
    If you wouldnt mind helping then can you please tell me what the difference between a rom and kernel is?
    i want to root with "simple root" and update to 1.47, but after that i want to do the set CPU thing, but i dont want to reaply it every boot, so i want your custom kernel cuz you said it disables that
    and does this kernel ruin anything? (wifi, camera, 4g?)
    im consfused and just would like some answers, because all these roms sound nice, but then theres "kernels" and "radios" and "wipes"....im lost
    after i root, do i need to wipe to use that kernel?
    and is it a stock kernel? again i dont know if its like a rom or whatever
    Think of the kernel as a replaceable part of a ROM. Some Roms come with their own custom kernel, and you are able to find kernels by themselves, which are not tied to a single rom.
    You might want to flash this kernel instead since its more recent [Kernel]netarchy-toastmod, FPS 'fix' for Epson + Nova, now with hdmi - Version 3.7.5 - xda-developers
    If the kernel breaks anything, it will be listed in the kernel thread's first post. You don't need to wipe before installing any kernels. The kernel is "custom" so by definition it is not stock.
    07-29-2010 12:23 AM
  3. rocklee99's Avatar
    can i ask why i should use the one you suggested? is there much of a difference in the two? and how do i know if a kernel breaks?
    edit: oh wait, that link you showed me is newer than ur first post?
    07-29-2010 12:42 AM
  4. pingpongboss's Avatar
    Yes, the one I put on the OP has not been updated since 7/7
    It doesn't really make sense to say the kernel "breaks". If it freezes your Evo all the tome or something then just restore from the backup ROM Manager made.
    07-29-2010 12:47 AM
  5. rocklee99's Avatar
    no one more thing, about those backups, what and how does nandroid backup work? and whats this rom manager?
    btw your the best, thanx for all the answers, your awesome!
    07-29-2010 12:54 AM
  6. rocklee99's Avatar
    hey, you said some kernel arent attached to roms, like this one, does it need to be?
    and do u need specific radio files or anything for this kernel? or am i ok, just flash and were good?
    07-29-2010 01:01 AM
  7. rocklee99's Avatar
    again, sorry for so many questions, but heres a different one, the froyo 2.2 update has just been rolled out OTA, so uhh, i installed the kernal that u gave me in the link above, so now...how do i keep the kernal and go to froyo 2.2???
    and when i install a different rom, will this kernal be erased?
    07-29-2010 07:19 PM
  8. meyerweb's Avatar
    I gotta tell ya, PPB, I'm a little confused. When I reboot I immediately get notification that SetCPU has been granted SU Permissions. The same for Titanium Backup. I've stopped doing Preflock because I don't think it's doing anything. At least no difference that I can see or measure. I've never gotten above 1307 on Long Bench.
    lol yea that's why I'm saying I can't explain why it's not working for you. If you've never gotten above 1307 then it means you've never been able to force the CPU to be 245mhz. For some reason Perflock Disabler is not working for you.
    I'm rooted with unrevoked3, otherwise completely stock ROM. I sometimes have to try the Perflock disable 4 or 5 times before it takes.
    First time I've heard of it too. Maybe it's an unrevoked 3 thing?
    I still need to run the perflock disable after unrevoked3.
    And let me add my thanks to the developer of this. My battery life is dramatically better. I've been having problems the last 2 days with auto-sync getting turned off, but I can't imagine that's because of this.
    07-29-2010 10:08 PM
  9. rocklee99's Avatar
    hey does the kernel i used affect this at all? and does doing this REALLY affect my battery life or not much?
    07-30-2010 11:22 AM
  10. pingpongboss's Avatar
    nandroid makes a perfect backup of everything, so when you restore the backup, it's exactly as it was before. I think it makes images of the system's partitions, thought I'm not exactly sure.
    just flash and follow the specific kernel's directions
    Make sure you use a kernel advertised with 2.2 support. The latest netarchy kernel in XDA has 2.2 froyo support. Yes, kernels get overwritten when you install a ROM.
    Yes. Kernels might be undervoltaged at lower CPU speeds to further save battery life. Read the kernel's thread to find out more about each individual kernel. Back when I had 2.1 on my Evo, this saved a boatload of battery. I haven't done much testing since the OTA, but on Froyo it seems like battery life has not been improving as much. I'm on CyanogenMod.
    08-06-2010 02:27 AM
  11. xorbe's Avatar
    I don't think nandroid backed up everything ... wasn't there a row about the wifi partition not backed up after the 4G key was corrupted?
    08-06-2010 08:12 PM
  12. pingpongboss's Avatar
    wifi partition?! 4g key?! Either you know something I don't, or you have very bad memory :P Wifi partition certainly doesn't make sense to me..
    08-06-2010 11:23 PM
  13. Loogie's Avatar
    What is the App you are running in the first post to show the historical performance data?
    08-22-2010 09:34 PM
  14. pingpongboss's Avatar
    SystemPanel on the market.
    08-22-2010 09:35 PM
  15. Loogie's Avatar
    Thanks!
    Ok, here's a question for the EE types out there (which I am not).
    If you have a processor running at 1ghz and it completes a task in 1 second and then you underclock it to 250mhz and it completes the task in 4 seconds have you saved any power? I'm not sure if the power consumption curve is linear or not. I seem to recall way back in my brain that it is linear which would make me think that you would just be breaking even in the above scenario. I'm sure that there are a bunch of other factors that I have not taken into consideration here (like system overhead processing) but I'm just interested to figure out why the underclocking seems to work from a technical perspective. Can anyone shed any light on this?
    08-22-2010 10:08 PM
  16. Ky1e.YC's Avatar
    That's something awesome...
    08-22-2010 11:31 PM
  17. statona's Avatar
    I'm using the Incredible... and it all seems to work great... of course, I have no idea what I'm doing - so thanks to PPM for his great and simple guidance.
    However, am I supposed to set the main screen max back to 998 after I have set the profiles, enabled the profiles and disabled the perflock?
    08-25-2010 05:38 PM
  18. pingpongboss's Avatar
    Thanks!
    Im also not fully sure on the details, but i'm almost 100 percent sure that an underclock will save battery, and an overclock will wreck your battery.
    From what i've seen, the main tab just seems to reflect whatever profile the system has currently made active. So changing the main tab wont do anything.
    08-25-2010 05:44 PM
  19. KSmithInNY's Avatar
    I think this is true in certain scenarios but not always. An example of when you don't need to set the main screen is how you (pingpongboss) have your profiles setup. Because your profiles basically cover every aspect of the phone from charging, to screen off, to screen on .... your profiles take precedence.
    An example of when the main screen actually does control the CPU is situations where the user does not have a profile set for a situation:
    Screen off - min 245 max 245
    Charging - min 998 max 998
    You can see though that in the example I didn't have a profile setup for when the screen is on, and not on the charger. This is where whatever you set on the main screen now takes precedence. So in the example above, if i set my main screen at min 245 max 576, when the screen is on and not on the charger the CPU will max out at 576.
    Keep up the great work. I love this thread.
    pingpongboss likes this.
    08-25-2010 07:06 PM
  20. UTnick's Avatar
    i'm just gonna move this up a little bit.
    08-27-2010 03:28 PM
  21. d3xn2o's Avatar
    Dont you mean....
    BUMP!
    08-27-2010 03:35 PM
  22. imex99's Avatar
    I'm running damage control, what would my best setcpu settings be?
    08-27-2010 10:44 PM
  23. g_b_h's Avatar
    Question for the OP..
    Are you still getting what you consider better battery like with SetCPU after you updated to Froyo? Also, do you still run that Task Killer? Isn't it possible your improved battery life is due to the TK?
    A better control would be to remove the TK, then to try the handset with/without SetCPU.
    My experience is that SetCPU makes like or no difference to Froyo's sucky battery life. Froyo is noticeably worse than 2.1, at least for me.
    08-28-2010 08:46 AM
  24. Kevin OQuinn's Avatar
    Read the thread for your ROM over on XDA. I'm not sure but I think damage control has a lot of tweaks for battery life already built in. That being said, if the kernel that installs with that ROM has perflock disabled already and it doesn't have value already built in you would benefit from these setting in setCPU.
    I have noticed a gain in battery life with these settings. It also has a lot to do with the ROM you run. I'm running the AC ROM which has other things done to improve battery life. When developing the ROM the devs made sure that they weren't gonna have bad battery life. My girlfriends EVO is not rooted and has no tweaks done to it or anything to improve battery life. She has the Froyo OTA on her phone and gets great battery life. Some FROYO ROMs go for performance more than battery life so depending on which one you're running that might be the reason why.
    08-28-2010 11:38 AM
  25. Kevin OQuinn's Avatar
    I noticed that with the AC ROM you can go as low as 128mhz, but it causes some issues. Waking up was buggy, and getting phone calls when the screen was off was almost impossible. By the time it woke up enough to answer the call I missed the call. I stepped up to the next lowest (the one in the pictures from the OP) and I have had no issues at all.
    08-28-2010 03:12 PM
87 1234
