Results 1 to 25 of 87
- 07-08-2010, 03:10 PM
Thread Author #1
- 07-08-2010, 03:23 PM #2
Sweet write up, man!
- 07-08-2010, 04:00 PM #3
Should probly go to the root section.,...
edit: roms and hacks section
http://forum.androidcentral.com/htc-evo-4g-roms-hacks/Last edited by liquidjesus; 07-08-2010 at 04:27 PM.
"In Soviet Russia, Android roots you!"
I'm here because like you, I have questions that I need answered, and help those like me, with questions of their own.
"If I have seen further it is by standing on the shoulders of giants."
-Isaac Newton, Letter to Robert Hooke, February 5, 1675 - 07-08-2010, 04:09 PM
Thread Author #4
- 07-08-2010, 04:27 PM #5
post corrected. see above!
Thanks for the great info though!
-Isaac Newton, Letter to Robert Hooke, February 5, 1675 - 07-08-2010, 04:54 PM #6
Hmmm, what does Perflock Disabler actually do? I don't understand how it can account for such a significant difference in the slope. Isn't it basically doing the same thing that the Overclock Widget does (or what it's meant to do)?
- 07-08-2010, 04:57 PM
Thread Author #7
Ah, I thought about it at first, but then again this is something you do AFTER you've gained root, so I didn't think it belonged there. But if a mod feels like it does, then I don't mind this thread being moved.
The Disabler just removes HTC's restriction on the kernel. With Perflock enabled, you could try to set your CPU to go to 245Mhz when the screen turns off, and it would SEEM to work, but it actually wouldn't do a thing. With the disabler, you can now control the speed of the CPU completely. That's why this is a big battery saver, because we are forcing the CPU to go super duper slow whenever the screen is off. - 07-08-2010, 05:00 PM #8
I see... Now, how does this affect applications running when screen is off? Such as Pandora, Slacker, mail syncing, etc?!
- 07-08-2010, 05:02 PM
Thread Author #9
Applications will run much slower (but you won't see an effect). For example, doing a Long Benchmark and turning off the screen will get you something close to 5000ms as opposed to 1000ms. You can test this if you like.
But apps like Pandora, Slacker, syncing, etc do NOT need 1Ghz to run. 245Mhz is more than enough for your apps to finish their tasks in the background. - 07-08-2010, 05:31 PM #10
- 07-08-2010, 05:37 PM #11
No need to send folks to other sites for kernels
http://forum.androidcentral.com/htc-...tml#post205021
Normally i don't toot my own horn, but it'll rock your socks off
(•‿•) - 07-08-2010, 05:53 PM #12
OP,
Could you please post a pic of the lower half of your profiles screen please.
Not sure what to set the rest of mine too..
Thanks again! - 07-08-2010, 05:56 PM
Thread Author #13
- 07-08-2010, 06:12 PM #14
Not really sure why there is a need for this when the Snapdragon already auto justs Mhz to conserve battery? you can download tools to verify. pegging your processor at 245mhz while the screen is shut off, why not just turn your phone off if you are that concerned about battery life?
- 07-08-2010, 06:15 PM
Thread Author #15
Yes, the processor does indeed auto-adjust itself. But the thing is, when your screen is off, it could still go up to 1Ghz if it detects Pandora running or if Facebook wakes up to do a sync. It happens a lot more often than you might think, and the processor is RARELY auto-adjusted to 245Mhz.
With SetCPU, you can tell the CPU to always stay at 245Mhz when the screen is off, giving you free battery life while not sacrificing anything (much)
Edit: See that 8 hour battery graph in the OP? Before, when the CPU was auto-adjusted, the battery would have gone to around 0% while it idled. Now, it's going to around 95%! Isn't that crazy - 07-08-2010, 06:31 PM #16
- 07-08-2010, 06:42 PM
Thread Author #17
With a custom kernel like the one I have, you don't need to use the Perflock Disabler, since that kernel has already removed the perflock. You can flash that kernel, and immediately start messing with the CPU speeds in SetCPU.
Fresh comes with the stock kernel, so it should work perfectly with the Perflock Disabler. - 07-08-2010, 07:12 PM #18
I just installed this two days ago. Works great. I haven't noticed much on the battery life end, but I got good battery life to begin with. What I do notice is any slow downs that I may have had before installing this are gone. The phone runs smooth as hell all the time.
- 07-09-2010, 01:49 AM #19
How stable is this SetCPU hack? Shortly after I tried this, Launcher Pro started lagging really badly, and I had to restart the phone. Then after the reboot, some time later, Awake Time started tracking Up Time at 1/2 the speed (2 Up 1 Awake) -- couldn't see anything to account for the behavior. I restarted again, and that's fixed now ... nothing conclusive, but if other people see similar things, do post please. A clue is when the phone gets warm your pocket ...
- 07-09-2010, 01:52 AM
Thread Author #20
- 07-09-2010, 09:56 AM
Thread Author #21
A few people from XDA have reported that they get better battery life with Sleep profile set to 245Mhz instead of 128Mhz for whatever reason. I'll have to test this myself.
- 07-09-2010, 09:59 AM #22
"The last entry is Battery < 100%, set at lowest priority, with MAX as the highest value, MIN as the lowest value, and scaling as ondemand."
By lowest priority do you mean 0 or 50?
Also, as you mentioned, do you have to set this every time you reboot? Will Checking Set on Boot not work? - 07-09-2010, 10:27 AM #23
Yeah, it's odd how there is no "and if nothing else was matched" default rule! The logic experts pick out "battery < 100%" or "temp > 0C" but that's not so obvious probably.
RoboDefense kept glitching to the home screen and then reloading after the last reboot + SetCPU. All 3 things have never happened before until SetCPU, but that's still not conclusive of anything. - 07-09-2010, 10:57 AM #24
Yea this technically is still a root operation...
This Could get over run with non root users asking tons of Questions...
BTW: We have the same set up...
Wifi was Broken for a little While but then i wised up and flashed Wifi-N all is well in the world again..
Arrogant Linux Elitist - 07-09-2010, 12:27 PM
Thread Author #25
Lowest priority relative to the other profiles I should've said. So just choose 0 if you're not sure.
The battery < 100% is the "catch-all". I would love to have my battery > 100% though
Are you using the stock kernel? If you are, then it may be because the Perflock Disabler is still beta. If you're on a custom (overclockable) kernel, then maybe your phone can not handle the speed you set it as.
haha yea when I first flashed the kernel I couldn't figure out why my wifi stopped working either
Reply
