Results 1 to 7 of 7
    marshall_634's Avatar
    Posts
    Global Posts
    80 Global Posts
    ROM
    Myn's Warm TwoPointTwo RL
    Default Help with SetCPU and VaelPak
    Everytime I set setCPU to the max, it freezes my phone and I have to reinstall the ROM. but if I set setCPU at around 105000 on the max side. it runs fine. Anyone know what I am doing wrong.
    Kernel 2.6.32.15-king-HAVS-ocUv
    erik@Ubuntu #8
  2. #2
    Default
    Your phone probably just cant handle higher clock speeds, thats all. Just dont set it any higher.
  3. #3
    b0ricua's Avatar
    Posts
    Global Posts
    470 Global Posts
    ROM
    MikG 2.56/Freedom 0.9
    Default Re: Help with SetCPU and VaelPak
    Quote Originally Posted by gabbott View Post
    Ditto, experiment with frequencies incrementally. And make sure to uncheck "set on boot" when you're experimenting.
    Swyped from my HTC Evo 4G
  4. #4
    1.15GHz is the OC rate responsible dev's are going with because most phones will lockup/bootloop on anything higher.
  5. #5
    Jerry Hildenbrand's Avatar
    AC Cowboy
    Posts
    Global Posts
    5,839 Global Posts
    ROM
    Homebrewed
    Default
    Try another kernel
  6. #6
    mrich70's Avatar
    Posts
    Global Posts
    55 Global Posts
    ROM
    MIUI 2.5.18(ICS) w/Tiamat
    Default
    Quote Originally Posted by KSmithInNY View Post
    How do u fix the loop once it begins. I was trying to raise the max setting using Set cpu and got caught in a loop. I did have the reboot option checked. Maybe that was the problem.
  7. #7
    Default
    Ya it's def not the rom. It's the kernel. I can set mine to 1190 with no problem. But not matter what kernel I use the moment it hits 1228 it locks up. The best thing to do is when you reboot your phone, as soon as you can open set pcu and lower the cpu numbers.
    How to flash a rom on your htc Evo
    Proud owner of a CR-48--My review of my CR-48
    iPhone > Instinct > Hero > Evo 4G > Evo 3D
    Evo 3D OOWNNSS!!!!!!!!!!!!!
    Twitter
    PS3- SpiderMonkee
