1. mrsplashystats's Avatar
    In the picture below you will see the number "0" in spare parts under network usage. I have searched the XDA threads and tried google and have found no answer. This "0" never use to be there before and is using a lot of data which is killing my battery. Yes I have always wiped when going to a different rom, I have even tried reinstalling my rom again and fully wiping. The rom I am currently running now is airborne 5.1 with kernel SBC for Netarchy's 4.2.2 More Aggressive CFS SBC-net-4.2.2-more-havs-cfs-v7. I also know the kernel is not a problem because when I reinstalled the rom I did not add any of my apps or nothing and nor did I flash anything else. I just let my Rom load up downloaded spare parts just to see if the "0" was there and it wasnt, but once i rebooted my phone just to make sure it was really gone, I went back into spare parts and it was there again. Now my question to you guys is how do I get rid of this problem?
    12-27-2010 04:37 PM
  2. durandetto's Avatar
    I had the same problem on my Hero too. When you click on it it fcs settings. Never could figure out what it was.
    Sent from my EVO 3G!
    12-27-2010 06:54 PM
  3. willy900wonka's Avatar
    Home land security is watching you.
    OK so maybe not, but a process called "0" is running all the time. Usually the lower the pid the more essential the process. So a" leakage" is screwing with your phone. Get a communication monitor and check with whom it's leaking.
    12-27-2010 08:39 PM
  4. mrsplashystats's Avatar
    yesss its always force closes on me when i try to open it and see whats up -_-
    12-27-2010 09:21 PM
  5. mrsplashystats's Avatar
    what would you recommend me using because I currently have system panel installed on my phone
    12-27-2010 09:25 PM
  6. PM-Performance's Avatar
    I cant answer what the zero is, but I have seen it come up on builds wether I was having a problem or not. So I wouldnt focus on the zero part too much
    for your data usage though or to see what is killing your battery, check your radio version and PRI. I had this problem last week with a radio and needed to use an updated radio because the old was keeping my phone awake on 3.70
    I have also had my phone stay awake from trying to send a large email that just kept cycling in my phone trying to sync and send and never sent due to size.
    12-28-2010 06:50 AM
  7. mrsplashystats's Avatar
    My baseband version is 2.15.00.07.28
    My PRI version is 1.90_003
    and my PRL version is 60674
    so should i update my baseband (the radio) ?
    12-28-2010 04:53 PM
  8. PM-Performance's Avatar
    I had the same radio and was having problems on the 3.70 builds.
    If you know how to update the radio and feel comfortable with it, I would suggest the newest one. (what i did)
    It fixed my problem and when I posted that as the fix on XDA plenty of other people confirmed it worked for them also.
    12-29-2010 09:06 AM
  9. mrsplashystats's Avatar
    I will try updating the radio and see if that improves my battery life if not ill report back and thank you for your help i really appreciate it.
    12-29-2010 08:27 PM
