Results 1 to 7 of 7
- 01-12-2011, 12:56 AM
Thread Author #1
Need help with MMS issue with CM 6.1.2.
hey guys and gals..
I need some help here..
I rooted my phone using unrevoked and used clock work to backup and flash my evo (did a wipe and cache wipe as well when I flashed to the new ROM).
I currently am running update-cm-6.1.2-DesireHD-signed.zip WITH the Google apps as well.
I have been able to receive MMS messages but can not send them. I can not send them with the stock SMS/MMS application NOR can I send them with handcent. I just get a "sending".
Any help here would be great.. It's rather annoying not being able to send off a picture message. Other than that, everything is amazing! - 01-12-2011, 07:23 AM #2
this post had old info, see below for a way better/faster answer!
Fred
@thefredelement - 01-12-2011, 10:20 AM
Thread Author #3
thanks fredelement, but dang.. 1700 pages? haha.
If i flash back to my stock sense rom, then back to my CM6.1.2 am i going to have to set CM6 back up again?
Or can i just make a backup of it through clockwork and just get it back teh exact way it is now? - 01-13-2011, 02:54 PM #4
hey whitehorse... i think you posted in the cm forum (under whitehorsedp) too... but for future reference for the ac community deleting the telephony.db file in folder /data/data/com.android.providers.telephony/databases followed by a reboot worked for me. for a while i though i was giving up both mms and 4g for cm... now, only waiting for 4g
Thanked by 2: - 01-13-2011, 03:35 PM
Thread Author #5
thanks quocamole!
I was finally able to find the /data/data file and get rid of it... using handcent and everything is working smoothly. - 01-13-2011, 04:48 PM #6
Why are you using the desire hd rom?
...Some say the glass is half empty. Some say its half full. I say, "Are you going to drink that?" - 01-13-2011, 04:59 PM
Thread Author #7
sorry, i copied that link name from the incorrect place.
i am using 6.1.2-Supersonic
Reply
