If you haven't used unrevoked forever in your root process you don't have to use this guide and can use the original how to unroot your phone guide here: http://forum.androidcentral.com/htc-evo-4g-rooting-roms-hacks/19278-how-unroot-return-stock.html
If during your root process you flashed unrevoked-forever.zip or used the Unrevoked program to root your phone then you should follow this guide. In short if you ever had factory software 3.7 or hboot 2.02 on your phone you had to use unrevoked-forever to get a full root.
This guide will return your phone to 3.7 factory software and will restore the HTC security software check.
1. Download some files:
Unrevoked S-ON tool: http://downloads.unrevoked.com/forever/current/unrevoked-forever-son.zip
HTC RUU (rom update utility) for 3.7 software. Get this file: RUU_SuperSonic_S_Sprint_WWE_3.70.651.1_Radio_2.15.00.11.19_NV_1.90_release_161482_signed.exe from here: http://goo-inside.me/evo/stock/RUU/
The second file is kind of big, so charge your phone in the mean time.
2. Put unrevoked-forever-son.zip on the root of your sdcard.
3. Reboot your phone in to recovery
4. Install ZIP from sdcard, select unrevoked-forever-son.zip (It may need to reboot to complete the process, if so just hit reboot from the main menu and it will take care of it).
5. When the phone boots back up, make sure it's still connected to your computer and run the RUU exe file you downloaded earlier.
Some times it takes more than a few tries at getting the RUU to connect and run, you can try to re-start your computer or put your phone down in to hboot usb.
When it completes you'll be at factory software version 3.7 with S-ON.
