Results 1 to 6 of 6
- 10-12-2011, 01:04 PM
Thread Author #1
Evo Power Button not working! Help!
So I hit the power button... And nothing happens. To turn my phone screen on I need to plug it in, and then to turn it off I need to let it time out. What is going on? Any suggestions of how to fix this issue?! I need to use my phone! But I can't because of this issue!
- 10-14-2011, 10:51 AM #2
- 10-14-2011, 02:42 PM #3
- 05-19-2012, 08:26 PM #4
Re: Evo Power Button not working! Help!
I just started having this same problem. did anyone ever figure out how to fix it. btw I did install the unlock program and i am able to wake it up now with volume buttons, but what is wrong with my power button?
- 05-31-2012, 01:58 AM #5
Yeah I had the same problem. I solved it by:
- removing the cover that covers the mobo
- gently pushing the power button back (away from screen)
- I then cut up the cardboard from a gum package (like stride or trident) folded in half and put it between the power button and the front housing
- screwed the screws back in (just snug) and removed the cardboard.
There should be little space between the power button and the front housing. My problem was obviously that the button wasn't seated right. If this doesn't work then its probably a mobo problem. Just google how to take apart an evo and youll find hundreds of tutorials.
Hope this helps someone. - 05-31-2012, 04:34 AM #6
Reply
