EVERYTHING works perfectly on this amazing phone, EXCEPT the weather widget.
Basically, I just have the stock one running (giant flip clock with the location and current weather underneath). The time is correct, but it cannot lock down my current location correctly. And now, the weather has disappeared alltogether from the widget. The weird part is, when I pull up google maps, it has me located exactly right (after about a 3 second delay. The circle starts about three blocks away, then zeroes in).
I've tried it with 3g,wireless, gps, all on and off. Also tried trashing then reinstalling the widget several times. The OTHER weird part is, when you actually click on the widget, it says weather update not available for current location, but my secondary location (denver) updates just fine.
The last bit of info...this was all working fine until I did a hard reset (i had loaded old contacts, linked some profiles wrong, etc etc, so just decided to start fresh), but since then it has ceased working.
Feeling VERY hero-esue in the weather widget regard unfortunately
Everything else works perfectly, and I love this PHONE>
And yes, I realize I can download a different weather widget, but I really like the look of the stock one.
cheers and thanks
cheers and thanks
