Results 1 to 7 of 7
    djjeffa's Avatar
    Posts
    Global Posts
    96 Global Posts
    Question need help picking out a cheap battery for an evo 4g
    mo OEM one is beat, battery monitor says its around 800mah so I got a 3500mah off ebay but it seems to be floating between 1400 and 1800mah im not sure if im using battery monitor right but iv ran many full charge cycles and updated the mah to 1557mah witch is what it was reading measured witch I hope is ow I suppose to use it but back on topic if this reading is right i rather just run oem since ill only lose around 1000mah but the phone will be small again. any recomendation for a batter I could get for around $10 that will put out 1500 or more mah but still be oem size?
    soory for the long boaring post.
    get in da mix
  2. #2
    Pre-dawn raid's Avatar
    Posts
    Global Posts
    320 Global Posts
    ROM
    stock 4.2.1; CM7.2(nook)
    Default Re: need help picking out a cheap battery for an evo 4g
    Ever heard of a period? A little hard to make sense of your post to be honest.
  3. #3
    Quote Originally Posted by djjeffa View Post
    Try searching ebay. I purchased two 1500mAh batteries and a charger for less than 8 bucks. It's been sometime ago and I have not had any problems with either of the batteries. Also you can plug the charger up to AC or USB charging..
    Here is a link
    Ham
    djjeffa's Avatar
    Posts
    Global Posts
    96 Global Posts
    Default
    Quote Originally Posted by Pre-dawn raid View Post
    To keep it short im looking for a oem size true 1500 or more mah i got a ext 3500mah but battery monitor is telling me its 1800
    looking to spend around $10
    Quote Originally Posted by HamRadioNut View Post
    Here is a link
    Ham
    Thanks did you run batter monitor to see what the true mah is cause I heard the true mah of oem are only 1400 mah
    Sent from my EVO using Tapatalk
    get in da mix
  5. #5
    dumpedduce's Avatar
    Posts
    ROM
    Arctic Hd
    Default
    Don't expect a 10 dollar battery hold what it says its gonna do. Wanna be cheap, well, you get cheap crap. Buy a quality battery and be done.
    My .02
    Sent from my Eclipsed Droid RAZR via Tapatalk II
  6. #6
    No I did not. I just wanted a couple of extra batteries in case I needed one. They both however lasted just as long as the oem and now that my oem battery is lasting longer I hardly ever use the extra's....
    Ham
    djjeffa's Avatar
    Posts
    Global Posts
    96 Global Posts
    Default
    Quote Originally Posted by dumpedduce View Post
    My .02
    I dont thats why im asking if anyone tested them if they say 2000mha maybe there 1500 witch is good enought for me. Im looking to get the evo lte but until then i have some runs comming and i use my phone for music but i would like a oem size batter so it will fit in my pouch.
    Ham
    Thanks for the info ham i might give them a shot.
    get in da mix
