Now First you need to Root the phone
either the Toast root method or the super easy unrevoked method unrevoked
Now Download from the Market AutoKiller and Overclock Widget
Now put the Overclock Widget on the Homescreen Click it then go to Advanced Setting
On "Screen On Freq Setting change it to
Min: 245000
Max:998400
Check Differ Freq Screen Off
Now
On "Screen Off Freq Setting
change
Min 245000
Max 245000
Then go down and check Supress Notification
Then Check Auto Start on Boot
and Save!!!
Now go to AutoKiller and Put in Custom Settings of
Hidden App 100
Content Provider 110
Empty App 120
and Apply
This has giving me WAY more battery life it pretty much uses none while the screen is off I unplugged my phone at 10 am and used it and at 2pm it barley went down!!
Min: 245000
Max:998400
Now
change
Min 245000
Max 245000
and Save!!!
Hidden App 100
Empty App 120
and Apply
