06-13-2010 02:33 PM
26 12
tools
  1. splmonster's Avatar
    At least from looking at my battery use my Cell standby is 35% but the time without signal is at 0%. My phone idle sits at 29%.. Do these seem high? My Android system is only using 20%, and Display is at 6%. Also to add... My phone was fully charged at 100%, and after only 5h 10m its at a little over a quarter battery left with very little use. To me this seems horrible...
    GPS off
    4G off
    Nothing synced except my gmail and weather sync every hour.
    Auto Brightness
    06-13-2010 12:41 AM
  2. splmonster's Avatar
    Anyone? Why is my battery dying so quickly? Even after all the battery tricks.
    06-13-2010 03:05 AM
  3. pingpongboss's Avatar
    Yea, coming from a Moto Droid these percentages seem horrible. But it's normal for a Evo. Not sure why though.
    06-13-2010 04:08 AM
  4. markdek's Avatar
    GPS off
    4G off
    Auto Brightness
    Well, the Percentage of battery use displayed has to add up to 100%, so I'm not sure what you are asking. Something has to be using the battery, even when it's locked. If you have very little background data processes running, then it would be expected that "Cell Standby" would have the largest percentage of use. These are Percentages right?.........these percentage statistics say nothing about the life of the battery. I think you want to look at total time versus up time for and battery life issues. Then if you see a problem, then maybe look at some of the statistics. But by themselves and without more info, your stats can be interpreted as good or bad.
    06-13-2010 04:54 AM
  5. orlandojumpoff's Avatar
    5 hours with little use and with a quarter battery left is terrible. i get 24 hours with light use give or take a few hours.
    have you tried installing the app called Network to see if your preferred network is set to gsm instead of cdma auto?
    06-13-2010 05:07 AM
  6. Gekko's Avatar
    1. move your display brightness lower to the extreme left to where the lever is under the checkmark. yes this is a low setting but plenty bright for me. also TURN OFF auto brightness.
    2. turn off WIFI.
    3. turn off "always on mobile data".
    06-13-2010 06:14 AM
  7. deparson's Avatar
    Nothing I did worked until I installed ATK and now I get over 15 hours down to 30%.
    GPS off
    4G off
    Auto Brightness
    06-13-2010 07:12 AM
  8. markdek's Avatar
    Yes and no...the max "use" time I could get out of my Evo was 6 hours (11 - 12 hours on time)....pretty constant use.
    To get that 24 hour time, how much "use" or "up" time did you have, or do you get?
    06-13-2010 07:15 AM
  9. Gigity's Avatar
    2. turn off WIFI.
    No offense, but a phone should not have to be babied in this way. When HTC states the standby time for this phone, do they have a disclaimer stating that you basically need to turn every antenna off to achieve it?
    06-13-2010 07:16 AM
  10. Gekko's Avatar
    babied? this is common sense. don't use power hungry features until/unless you needed them if you want max battery life. the laws of physics have not changed.
    06-13-2010 07:26 AM
  11. Gigity's Avatar
    A properly made phone won't need wifi shut off in order to maintain long standby times. Or GPS. Ive used plenty of phones and have never had to baby them simply to maintain standby times like a lot of EVO users appear to have to. And from the sounds of it, Froyo will address many of these issues. So fortunately for EVO users Google is aware that their battery management needed much improvement.
    06-13-2010 07:38 AM
  12. cheebahawk1's Avatar
    Wut smartphone have u used/owned that didn't need those features turned off when not using to conserve battery life.
    I have been using smartphones since Treo days, n never came across a device that u describe.
    06-13-2010 08:18 AM
  13. Gigity's Avatar
    With Wifi and GPS enabled, my 3GS will sit for days without hardly any battery drain. Add to that a push messaging app always running and sending notifications. The EVO is simply draining much too fast, and FROYO will address it, so its not like Google didn't understand where they needed improvements.
    06-13-2010 08:36 AM
  14. Carioca_FL's Avatar
    You can't really compare the 3GS battery with the EVO, since to have the convenience of user-replaceable batteries (and the ability to carry extras, something the iPhone was never able), you need to tradeoff battery size.
    We can't have our cake and eat it too.
    As for the tip to lower the screen brightness to its lowest setting -how can you even use the phone outside? Personally, I just keep the brightness at around 60-75%, don't let social-networking apps (and other online apps) update on their own, and GPS off. I'm able to use my phone throughout the day, though having a car charger and an AC charger at work/home really helps.
    I've ordered that (in)famous eBay set of 2 batteries and charger for $15, so I'm looking forward to reenable most of these settings.
    06-13-2010 08:49 AM
  15. MarqBland's Avatar
    Well when I first got this phone, I was worried about battery too. But after the first day, my worries left. I literally go all day and my battery will be at 50% at the end of the day. I don't use a task killer or anything. My gps stays on (but it isn't active unless being used). I am in the habit of turning wifi off when I'm not at home (just seems to make sense to do that). Other than that, I don't think I've done anything else for the battery. Heck, yesterday I watched at least half of the England vs Us game on sprint tv and my battery stayed full.
    06-13-2010 08:50 AM
  16. buggyman's Avatar
    sorry wrong thread
    06-13-2010 09:07 AM
  17. vikingjunior's Avatar
    I think what really kills the battery is say a half hour of surfing the web. Holy Cow!
    06-13-2010 11:09 AM
  18. splmonster's Avatar
    2. turn off WIFI.
    I don't have Wi-Fi on, and I will not turn off the "always-on mobile data". Reason? When I did this for battery saving, it made my phone constantly reboot and crash. Once I flipped it back on, had no more crashing.
    06-13-2010 02:13 PM
  19. stolirocks's Avatar
    3GS is not multitasking either. a 3GS is doing far less idle than the EVO is, or any other android phone for that matter.
    06-13-2010 02:19 PM
  20. stolirocks's Avatar
    if your phone did that when you turned that off then take it to be serviced. I gained a drastic improvement when turning off always on mobile data and my phone has never crashed. you might have other issues.
    I went through the whole day yesterday with moderate use of my evo 7:30am-11:00pm and ended up with over 50% battery left. and no, i'm not using a phone killer either.
    06-13-2010 02:21 PM
  21. splmonster's Avatar
    So why don't I have those issues now?
    06-13-2010 02:22 PM
  22. stolirocks's Avatar
    Maybe I just have good eyes but when indoors I keep my brightness to 20%, and never see the need to go above 40% outside.
    06-13-2010 02:25 PM
  23. stolirocks's Avatar
    dunno. hey do whatever you want. Just saying mine and many many MANY others have turned that setting off and had no issues with the phone crashing as you are describing. Maybe your network area needs that setting. no clue. if you read the little description near the setting, it tells you what it is for. maybe your area needs it. that would suck.
    06-13-2010 02:27 PM
  24. markwoll's Avatar
    My evo has 50% battery ( according to spare parts) after being taken off of the charger 31 hours ago.
    I have made some calls, watched a bit of world cup, surfed for a while, a bit of text, Pandora.
    I have it going for mail fairly often.
    All 3g. No task killers. I get pretty good signal around here.
    I do have the innocell 1750ma battery, but it is new and has not been conditioned.
    I was getting good usage out of the stock battery, at least a full day.
    I guess I doing it wrong.
    mark.
    stolirocks likes this.
    06-13-2010 02:30 PM
  25. stolirocks's Avatar
    mark.
    same here, I guess we are both using our phones wrong or are crazy.
    06-13-2010 02:32 PM
26 12
