1. pezdukie's Avatar
    So I just recently purchased the Motorola T505 to be able to stream Pandora and my Evo's music through my car stereo. The T505 works great, and has no problems with other bluetooth devices like my laptop.
    My Evo, however, does not work great. It pairs just fine, but every 10-15 seconds there is a 1-2 second pause where no sound plays at all, and then it resumes play until the next pause. It makes listening to music through the Evo unbearable; which is a huge disappointment considering this was one of the big features I liked of the phone.
    Any suggestions? Do I just have a faulty bluetooth transmitter, or could it be some software glitch because of certain apps I have installed? Any help would be appreciated.
    07-22-2010 03:09 PM
  2. scoobdude's Avatar
    Turn off WiFi and report back.
    07-22-2010 03:58 PM
  3. pezdukie's Avatar
    You, sir, are a stallion. Works perfectly after turning off WiFi. That is sort of a hassle that I have to turn off WiFi everytime now though.
    07-22-2010 11:06 PM
  4. scoobdude's Avatar
    not sure what the real problem is, but it works. I have been using quick settings to free up screen real estate from the BT, wifi and gps widgets. Might wanna give that a try. Might make things easier.
    also please report this problem to HTC so they are aware. Hopefully if they get enough complaints it will get fixed.
    07-22-2010 11:14 PM
