1. jgladstone's Avatar
    I have been using Vonage for years now....no problems. I havel always had my home voice mail messages forwarded to my smartphone for listening. This is done via email and vonage sends the voicemail as a .wav file. I received these normally with my EVO on Android 2.1
    Since the update to Froyo 2.2.....the program that EVO brings up to listen to the voicemail message (.wav file) says that it cannot read that file type. I can no longer listen to my voice mail messages.
    I'm hoping that someone else has experienced this and solved. I am at a loss. Thanks in advance for your help.
    08-06-2010 12:52 PM
  2. shadowgod's Avatar
    I don't understand why people are having this problem just surface now with 2.2, I couldn't listen to my wav voicemail even in 2.1. The problem is certain types of wav files that Google refuses to support in the O/S.
    Anyway, the solution is an app in the market called "Remote Wave" but it'll cost ya $3.
    08-07-2010 03:35 AM
  3. Phrozen2nd's Avatar
    I'm still on 2.1 and I have never had a problem listening to my Vonage voice mails. If this is true problem with 2.2, I will not be at a complete lost because I have visual voice mail through Vonage also. Sorry I can't offer anymore assistance.
    08-07-2010 06:05 AM
  4. fgkay's Avatar
    I can personally confirm that, before 2.2, .wav attachments from Vonage via gmail worked perfectly. Now, in 2.2, they are no longer supported. Don't know if this was a deliberate change or a bug, however.
    As mentioned above, Remote Wave will do the job but you'll have to pay the $3.
    As for Vonage Visual Voice Mail, I like it and it's a great feature to have but the transcription accurracy is spotty at best. For any messages longer than a sentence or two, you still need to listen to the actual message to verify the context. And, even if it transcribed perfectly, it only transcribes the 1st minute of a message -- anything longer and you need to listen.
    08-07-2010 08:12 AM
  5. jgladstone's Avatar
    Thanks for the responses. I knew that I wasn't the only one. HTC...r u listening? Please fix....wav files should be a no brainer.
    08-07-2010 10:39 AM
  6. nedfp's Avatar
    It is a Vonage issue. It is not a "true" wav file. The same thing happened to me on a Motorola Q. They use some kind of compression.
    09-02-2010 01:29 PM
  7. jcole01272's Avatar
    Not so, I also get voicemails sent to my email from my office phone that have no compression (trust me, like 3 v/m's and my inbox is full) and they are no longer playable either. With 2.2 the ability to play any type of .wav file natively was lost..
    09-02-2010 02:02 PM
  8. derek5l's Avatar
    Interesting
    09-02-2010 05:06 PM
  9. copperavery's Avatar
    Correct,in that no .wav files can b played. I have clearwire phone service, same thing, 2.1 worked ok, 2.2 DOES NOT Sprint rep says "working on it". Believe it when I see it.
    09-03-2010 12:44 PM
