WPA2 Wireless Problems
sqeet
22
I'm connecting to a work Wifi with the following settings:
WPA2-Enterprise with PEAP-MSCHAPv2 authentication using Radius. (i think i got all those details right).
Well, it typically works but occasionally for no apparent reason, when trying to update email for example, it will just give the "No Network Connection" error. Even though it shows the wireless as connected. Turning the wireless off and back on will resolve, but it happens fairly often enough to be a nuisance. Any ideas on what may be causing this?
sqeet
22
Bump, is no one else experiencing this trouble? Any ideas of where I might be able to go to find out any info? Other Android/Evo forums or such?
deaofly
355
14
Maybe its your connection settings. You have to remember that your work might have certain settings lined up to keep certain access to certain things. I know WiFi is way better then 3g but if you can get a good signal on 3g, why not just stick with that. Maybe the settings in the router block specific programs. They can be set up like that.
Chelsea rae
