Page 1 of 2 12 LastLast
Results 1 to 25 of 30
    Default How do I connect EVO to play thru my car's sound system?
  2. #2
    Default Re: How do I connect EVO to play thru my car's sound system?
    Aux cable. Your car needs the input though.
    Sent from my Precious using Tapatalk
  3. #3
    I bought a car holder that holds the evi and charges it and has a built in fm transmitter.
    Sent from my HTC EVO-4G using Tapatalk
  4. #4
    eldub1's Avatar
    Posts
    ROM
    Team Venom v1.2
    Default
    It also plays through a Bluetooth radio.
  5. #5
    Default
    Bluetooth....easiest and cleanest way to do it.......
    Anything that bleeds for a week and lives is pure evil
    Masshole!!!!
  6. #6
    Default
    Quote Originally Posted by c1971ace View Post
    Not exactly high fidelity though (in fact it usually sounds pretty terrible). AUX is the way to go if you have it.
  7. #7
    kd0axs's Avatar
    Posts
    Global Posts
    746 Global Posts
    Default
    As others have said, there are several ways you can do this.
    1. Aux cable is probably the best way if your head unit has an aux input. This is basically just a cable with a headphone plug at both ends. You can get them anywhere that sells electronics for about 5 bucks or less.
    2. Bluetooth is the cleanest way since it is wireless, but you need to have a head unit that supports A2DP.
    3. Cassette adapter. Cheap and easy if your head unit has a cassette player. These have been around since the days when everyone had those portable CD players.
    4. FM transmitter. These can be a little expensive for one that works halfway decent (around $50) but your only option if none of the above options will work for you.
  8. Thread Author  Thread Author    #8
    Default
    I have the aux cable but when i connect it it only plays thru the EVO and not tnru my car speakers
  9. #9
    Default
    Did you put your stereo on Aux? My car has one button that flips from CD/Radio and AUX.
  10. #10
    kd0axs's Avatar
    Posts
    Global Posts
    746 Global Posts
    Default
    You shouldn't be getting any sound out of the phone if you have the aux cable plugged in. Do you get the little headphone icon in your notification bar when it's plugged in?
  11. #11
    Default
    Mine plays & sounds good over Bluetooth, cuts the music when call comes in & uses car speakers to hear the phone call.
  12. Thread Author  Thread Author    #12
    Default
    No headset icon
    It worked with my itouch
    Using usb cable that camwe with thre phone. One end into phone other into the cars usb port
    Am i missing a step, need to hit a certain setting or download an app?
  13. #13
    Default
    You can't do that. We're not talking USB cable, we're talking the headphone jack. If your car stereo has an aux-in headphone jack, you want to use a cable and connect it that way. The only reason it worked with the iPod Touch is because they have special programming in the stereo for them.
  14. Thread Author  Thread Author    #14
    Default
    No headphone jack in car
    Any other suggestions?
  15. #15
    AndroidOne's Avatar
    Posts
    ROM
    Stock Android 4.0.4
    Default
    Quote Originally Posted by slider9499 View Post
    Other suggestions have already been provided on page 1, you just need to read and try them.
  16. #16
    Default
    I have a cassette adapter since I have a tape player but no aux input. It works just fine...
  17. Thread Author  Thread Author    #17
    Default
    Seems like HTC SCREWED UP BIG TIME AND SHOULD HAVE TAKEN A PAGE FROM APPLES PRODUCT
    THIS is wAY TOO COMPLICATED IN ORDR TO LISTEN TO A FEW TUNES IN MY CAR
  18. #18
    Default
    It's not even vaguely complicated. You just don't want to try the options given to you.
  19. #19
    kd0axs's Avatar
    Posts
    Global Posts
    746 Global Posts
    Default
    HTC didn't screw up at all. I'm sure they would love to make it work just like an iPod/iPhone but they can't because Apple has a patent on it.
    It's not complicated at all. You just need to look at the options and see which one works for you.
  20. #20
    Default
    Blame Apple/Your Car Stereo. It's a special iPod-only interface, there's no way HTC could do it even if they wanted to.
    There are cars that have better integration, like Ford's SYNC system. But for car stereos that only have iPod support, well, guess what? They mean it.
  21. #21
    Default
    Get an FM transmitter, such as this...
    Amazon.com: iriver AFT 100 Mobile FM Transmitter: $49.97
    Or upgrade your car's stereo deck with one that has an AUX input, such as this...
  22. #22
    AndroidOne's Avatar
    Posts
    ROM
    Stock Android 4.0.4
    Default
    I disagree entirely with your statement; I could argue that Apple screwed up big time by using a proprietary connector, and I would also be wrong. They are different products, you need to look for a solution that works with the product you own. Maybe in the end, your best option is to go with an Apple product.
    Have you considered going to a shop and inquire about adding an auxiliary stereo jack to your sound system? in some models is possible.
  23. #23
    Default
    It is only complicated if you try to use a solution that does not work
    If you don't have an AUX and you don't have Bluetooth and you don't want to use an FM transmitter take your car to a good electronics shop and have them 'fix' it for you!
  24. #24
    boggs3010#AC's Avatar
    Banned
    Posts
    Global Posts
    282 Global Posts
    Default
    I am currently using my phone thru my car stereo to listen to music. I bought a male to male plug in from radio shack. I think it was 8.99 for 6 feet took about 2 minutes to connect to the back of my stereo and then routed through my dash and up and behind the pillar and then to my phone.
    Works great and YES...the headphone icon is displayed on the phone.
  25. #25
    Default
    What kind of car or truck do you have? Make and model please. if you have a factory radio on something fairly new chances are you can get the hardware for a aux input to your factory radio.
B
