This is my first android phone and until now I haven't felt the need to root. I'll sit down over the weekend and figure it out. Thanks.
I might try flashing that hulufix.zip (from the link above) a bit later to see if that simple step works. Do a nandroid backup first, of course.
Edit: I just flashed that zip file (hulufix.zip), and it fixes the problem perfectly. I think it will require root to do it, though. I downloaded the zip to my phone and flashed it within RomManager.
Forgive my newbieness, but what Rom are you running? I'm wondering if this is as simple as rooting the phone, installing "rom manager" and using that. Were there any more steps?
I just verified with a friend's EVO that flash works before applying the recent update. It did, we checked cbs, etc. We applied the update and now those sites have the audio issue.
Has anyone found a solution yet, or know how to make Adobe aware of this?
I sent a message to HTC....they got back to me with general instructions to clear my Adobe Flash data and restart, which made no difference.
The only "fix" I've found is that I redownloaded Skyfire - I can still watch TDS and Colbert on that browser.
Thank you for your reply. To my understanding when you go to thedailyshow.com or colbertnation.com the sound seems to be off. It seems this would be a problem with the sites and not the phone, since the flash player works fine with other sites such as cnn.com. I have tested those websites with another Android phone and I got the same results. You may want to download a different browser from the Android Market. Due to the complex nature of this matter I believe we could provide the information you need faster and more efficiently via telephone. You may also call our Technical Support department at 866.449.8358. Of course if you?d rather continue via email I am more than happy to provide whatever assistance I can.
What HTC should understand is that those sites work fine before this MR. I had an EVO this morning and ensured it worked fine on all sites I tested (like CBS). I then applied the update, tried the sites again and the audio does not work correctly.
