Results 1 to 5 of 5
    xorg's Avatar
    Posts
    Global Posts
    1,010 Global Posts
    Default bluetooth uses more power than wifi since froyo
    Ever since Froyo, under Battery Use stats my EVO shows that Bluetooth is using more power (16%) than WiF (9%) with both powered on and WiFi connected to home router yet BT connected to nothing. Need to be on battery (off charger) for a couple hours before it shows up.
    Anyone else seeing this? A coworker is seeing the same thing. Is there a fix?
  2. #2
    z28marols1's Avatar
    Posts
    Global Posts
    76 Global Posts
    ROM
    Stock ICS, CM9, iOS
    Default
    It may not be so much a problem with bt as they may have just optimized the power consumption of wifi. Just a thought...
    Old flip phones - HTC Apache - HTC Mogul - Touch Pro - Palm Pre - HTC EVO 4G - iPhone 4S (current) -Motorola Xoom (current) - HTC EVO 4G LTE (current)
    xorg's Avatar
    Posts
    Global Posts
    1,010 Global Posts
    Default
    BT should be significantly lower in any situation.
    xorg's Avatar
    Posts
    Global Posts
    1,010 Global Posts
    Default
    Any one else seeing this?
    xorg's Avatar
    Posts
    Global Posts
    1,010 Global Posts
    Default
    BT for me now shows 22% while wifi only 8%. Work is connected bt is not.
