Results 1 to 3 of 3
    Ky1e.YC's Avatar
    Posts
    Global Posts
    396 Global Posts
    Default [HELP]Have some problem about SD Card
    Guys. need some help here. I had some SD Card problem tonight totally out of blue.
    Here is what happened. my evo was sleeping during last few hours, I tried to turn on screen by hit the power button mins ago. All buttons are lighted, but not screen. I was out of ideas but took off the battery, and reboot the evo. After reboot, there was one icon on the notification bar, "you can safely remove your sd card", I felt so strange, also, I cannot find lots of apps in the menu. I started to worry either my evo or the sd card itself.
    So I had another sdcard installed into evo. Fortunately, I can mount it with usb cable, also save/delete files on that sd card. So I believe it's my original 8gb sd card problem. I m thinking to fix it by formating or so. So, by adaptor, i connected it to my pc(win7), the bad thing is my system cannot recognize the sd card, there is even no new drive showing up(i did test on another sd card, when i hooked it up with the same adaptor, new drive popping up in the my computer).
    okay, guys, is there any one met such situation before? any way to diagnose and fix the issue? I do really appreciate.
  2. #2
    Ky772's Avatar
    Posts
    Global Posts
    46 Global Posts
    Default
    I'm having the same problem! It just happened a little while ago. Even after I pull out the battery and put the SD card back in, it's not reading it. Ugh...
    Ky1e.YC's Avatar
    Posts
    Global Posts
    396 Global Posts
    Default
    Quote Originally Posted by JillSandwich View Post
    Did you somehow try to fix it?
