Ok I have managed to get my phone to at lease flash a Rom and get it to work luckily but I realized that i wipe everything but it really isn't and not realizing that and I can't wipe and flash my file Roms because for some reason I have been getting some crazy wipes in recovery I keep getting this mtd: not writing bad block at 0x00000000
I:Set boot command "boot-recovery"
Command: "/sbin/recovery"
And way more errors to post but the main error is my mtd bad block not sure if I should delete the system in recovery or should I delete the data and then try again but I also had another alarming error it was symlink bad block not sync or something or other but is there another way other then the obvious like go into recovery to wipe the factory setting and cache but is there a way to completely fix my mtd block ? Any help is much appreciated thanks
Sent from my PC36100 using Tapatalk
