Results 1 to 14 of 14
    phrenom's Avatar
    Posts
    Global Posts
    18 Global Posts
    Default During Call - Power Reset???
    EVO 4G
    Issue: While on a call using BT headset & Google Navigation, I experienced a Power Reset 3 times yesterday & it has happened before. I am unsure what is causing it.
    It only occurs when on a call & navigating, but does not happen everytime.
    Please help!
  2. #2
    Default
    Thats weird, shouldnt it still be under warranty? id take it to a corporate store if its a constant issue. Ive never experienced it
  3. #3
    Default
    Quote Originally Posted by phrenom View Post
    EVO 4G
    Please help!
    What software version are you running? Are you rooted? What ROM are you using? What Kernel are you using?
  4. #4
    Default
    This happens to me EVERY time I'm on Bluetooth and running Google Nav while on a call. Very annoying. I'm running stock everything.
  5. #5
    Default
    I've had the same thing happen to me except I wasn't using the bluetooth either time. Just Navigation and received a call. After a couple minutes power reset. Battery was at 75% or better when this happened.
  6. #6
    Default
    This happens to me, but I have found that if I have the google navigation screen on top after making or receiving a call then it doesn't happen any more. Seems to be a issue with google maps working in the background during a call. I am a truckdriver so I use it this way alot.
    Thanked by:
  7. #7
    Default
    I have never experienced this, but I am rooted and running Cyanogen. Maybe some kind of memory leak. Are you guys running any task killers?
  8. Thread Author  Thread Author    #8
    phrenom's Avatar
    Posts
    Global Posts
    18 Global Posts
    Default
    Stock Android -
    phrenom's Avatar
    Posts
    Global Posts
    18 Global Posts
    Default
    I will try this.
  10. #10
    Default
    Stock Android -
    Are you running a task killer?
    I will try this.
    You will try what?
  11. Thread Author  Thread Author    #11
    phrenom's Avatar
    Posts
    Global Posts
    18 Global Posts
    Default
    no task killers. I am going to run Navigation in the foreground while on a phone call (see above comment from I.R.R.V.)
  12. #12
    Default
    I believe this is a known issue. Try searching it on the forums. I have seen it before. I happened to me a while back and I found it. Blue tooth on and telenav on.
    Swyped from my EVO using Taptalk Pro
  13. #13
    Default
    Local Sprint store says the multi time shut down is a software issue from the last update and the 0003 and 0004 hardware.
    My buddy was having that issue with his phone after the update, they swapped him phones (refurb) and the new one was worse.
    The last time he went in, the manager gave him a new phone in a box and it is working fine.
    She said they see alot of them doing it. She also said the next update should have it fixed in the next few weeks.
  14. #14
    Default
    Quote Originally Posted by bdmridgback View Post
    Gingerbread? :-)
    I've been having this problem before and since the last update. Looking forward to it being fixed. Will try not having G Nav in the background until then.
