Results 1 to 11 of 11
    Default 12.5MB dl speed 7 MB ul speed on 3G but I still get lag on XBOX LIVE?!?!
    How is this possible? I'm rooted with the WiFi Tether app. Why would I lag when I'm faster than some of my friends IP but they don't lag? Any ideas or suggestions?
  2. #2
    Default
    Your latency is too high. It does not communicate fast enough with the servers. You will need a land line.
  3. #3
    Default
    You also appear to have the fastest 3G in America.
    3G ping times are usually awful. 4G ping times should be better.
    Ping and latency are how fast your computer gets a request out and back. Gaming is pretty much lots of quick information bursts being sent. Each side has to send and confirm and exchange data. When you are just downloading, one side just sends and the other side listens. It would still be 'slow' to get started initiating the file download, but once started, you're flying since one side is basically just listening.
    Thanked by:
  4. #4
    kg4icg's Avatar
    Posts
    Global Posts
    710 Global Posts
    ROM
    Stock JB
    Default
    Now who's WiFi connection are you using, because that is not 3g or wimax.
    Thanked by:
  5. #5
  6. #6
    TWC_SouthPhilly's Avatar
    Posts
    Global Posts
    954 Global Posts
    ROM
    CM9...on both devices
    Default
    Quote Originally Posted by kg4icg View Post
    LMAO.... Right!!!
    Sent from my MIUI Havin, Gingerbread Throwing EVO 4G
    Devices: Samsung Galaxy SII Epic Touch 4G
    Samsung Galaxy10.1 16gb, Wifi
    Default
    I'm reading what it says on the tether app, those are the numbers its giving me, why would the numbers lie?
  8. #8
    Default
    go to speedtest.net and that will tell you your speeds better.
  9. #9
    Default
    Quote Originally Posted by dave84krueger View Post
    That's probably the total amount of data sent back and forth, not connection speed. Try speedtest.net.
    Sent from my HTC Evo using Tapatalk
  10. #10
    Default
    3g is probably not fast enough for anything on xbox live other than the dashboard and music. Even if your speeds are high enough your ping wont be good for playing online games.
  11. #11
    Cares's Avatar
    Posts
    Global Posts
    316 Global Posts
    Default
    What he said...
    Sent from my HTC Evo 4G
