1. mackgunz's Avatar
    my evo wont hold a charge ..a few weeks back it was working fine then one day it didnt chrage with the chrager i had so i found another one i had in my house was charging just fine few days ago it stop i have to kinda postion and bend the metal pary on the chager so it stay charging ..yesturday i had my phone off and charging around 5 hours the grren light did not come on but it shows that its charging i turn it on it says 51 percent so i leave it on as it charges then it slowly dies why its charging? i cant take it to best buy i hate there policy with the cheap loaner phones and they dont give you a new one unless you have them send it out over 4 times and i cant go back to sprint unless i get a new phone cant upgrade til july is there a way i can fix this
    04-10-2011 01:17 PM
  2. eldub1's Avatar
    Try to clean the port with a dry soft toothbrush or canned air. Hope that helps.
    04-10-2011 03:06 PM
  3. RkyMtnHigh's Avatar
    Might be the wrong charger (Voltage, mA) and it fried your battery. Original problem may have been a bad charger, or your battery telling you it was d-e-a-d.
    04-10-2011 03:42 PM
  4. tube517's Avatar
    Sounds like the USB port is faulty. You might have to call Sprint to send out a new phone.
    04-10-2011 04:05 PM
  5. snowwy66's Avatar
    try a BRAND NEW charger.
    i get the same problems you posted. everything says it's charging but it's not. new charger and problem solved.
    04-10-2011 04:16 PM
  6. boggs3010#AC's Avatar
    If it is the charger , try the battery. If not then it is the charging port. And that can be repaired. And if needed replaced.
    04-10-2011 04:27 PM
  7. EvilMonkey's Avatar
    Yeah...i just had to get my phone replaced due to a broken port. Thankfully they didn't charge me anything.
    04-10-2011 05:28 PM
  8. mackgunz's Avatar
    cant send to sprint they wont help because i have best buy protection which was a bad move
    04-10-2011 08:56 PM
