CM10 Bluetooth problems
Kazenoko
20
So I can't use my bluetooth at all. when i turn it on it says "turning on" stays like that for about 10 minutes then goes back to the off position. my bluetooth works fine before using the stock ROM. but it doesn't on CM10. any suggestions on how to fix it? or is it time for a new ROM? :/
lolinternet
157
5
New rom if you can't live without BT. It's a known issue and requires some seriously technical work to fix.
*Sent from work early bcuz some1 4got teh NSFW tag*
shawnnkushh
10
The only reason I recommend a new rom is because there hasn't been an active developer for this rom in months. I wish we could find someone to work some magic on our device but it looks bleak
wei34
