1. wv06's Avatar
    Personally I have been using the Platinum Case but I may upgrade to this Otterbox case now.
    Just got this in my email
    The wait is over!
    Click HERE to purchase your Commuter Series Case for the HTC EVO Shift.
    If you are looking for a tough HTC EVO Shift case, you've arrived at your best destination. Your new phone is socially skilled, technically advanced and fast as fast can be. Want to keep it damage-free? Then the OtterBox Commuter Series for HTC EVO Shift 4G is your answer. Three layers of protection, including built-in plugs for your phone's ports, will keep your new gadget safe from bumps, shocks, scratches and dust.
    Purchase the protection you need today at OtterBox.com.
    04-26-2011 01:07 PM
  2. ksims22887's Avatar
    if anyone get this case for htc evo shift please post review of it.
    04-28-2011 06:34 PM
  3. rdziagwa's Avatar
    My only complaint on this case is the flaps for the charger and headphone ports...they just hung there and didnt secure in like the other otterbox phone cases fo so I cut them off and now I'm happy with it!
    05-04-2011 06:07 PM
  4. TonyLibations's Avatar
    My Otterbox is scheduled to be here this Tuesday.
    05-06-2011 07:28 PM
  5. codylainsworth#AC's Avatar
    I have been using the case for about 3 weeks now and here is a quick review.
    First of all, I have to say I am very pleased with the case in general. One of my biggest concerns was how much weight it would add to the phone overall. Although I haven't weighed device+case, it is within acceptable parameters. That, obviously, is relative to each person and I can say that the phone didn't start out light from the beginning. But I like the heft of the device.
    I have had two other OtterBox cases over the years on two different devices. There is one big flaw in this case. This is my first slider phone so this very well might be a common irk to all cases that protect these particular devices. The rounded (or beveled) edges of the back piece help to decrease the footprint of the case overall. That lends itself to a really cumbersome act of sliding out the physical keyboard. If it is done in the standard way of holding the device, your/my fingers cradling the back tend to slide down the case, and increasing the possibility of dropping the phone. I have done it twice!! Thank god its an OtterBox case. Holding it that way takes a bit of time. It definitely isn't an easy feat. I often just put it in the palm of my hand and slide it with my other hand. I work in construction so I will have to live with that for now because I need the protection that no other case can provide.
    I hope this helps....
    05-21-2011 10:30 AM
  6. bullettrain's Avatar
    Is this case soft like the HTC branded ones at sprint or is it a harder plastic?
    Thanks.
    07-21-2011 12:57 PM
  7. crump84's Avatar
    Thanks.
    I'm not 100% positive but I believe all otterbox cases are hard plastic.
    Sent from my Gingerbread Speedy 4G using Tapatalk
    07-21-2011 01:42 PM
  8. cmags's Avatar
    Thanks.
    It's both. The case has three pieces. There is a single hard-plastic frame for the screen which clips on to the front of the phone, then the back has two pieces. There is an inner silicon skin which surrounds the back of the phone and a hard plastic cover that goes over this. The silicon is designed to provide shock absorption especially at the corners if dropped.
    I've got some close up pictures of the case in my for sale thread (and hit me up via PM if you're interested to buy it):
    http://forums.androidcentral.com/mar...-shift-4g.html
    07-22-2011 04:16 PM
  9. jakelaw#AC's Avatar
    Anyone have problems long term now with either the top or bottom piece coming loose due to the tabs breaking? They are available on Amazon for less than $20. Cmags, why were you selling yours?
    09-09-2011 06:36 PM
  10. teddysjam's Avatar
    Just ordered mine. Is there a holster or anything that will fit the Commuter series otterbox, or do you guys just put in ur pocket. I had an otterbox for my blackberry before the defender series it came with the holster included, but this one does not. I really like keeping it on my hip instead of pocket thanks
    10-08-2011 02:54 PM
  11. ksims22887's Avatar
    I have seidlo holster active for my phone it fit in there.
    10-08-2011 09:52 PM
  12. oneandoneeleven's Avatar
    I would really like to know the durability of this case from anyone that has had this case for a while.
    I've went through 2 Seidio Innocases already.
    Crappy design.
    I'm not rough on them. This is normal use.
    11-23-2011 12:51 PM
  13. jakelaw#AC's Avatar
    I had mine for a bout 6 weeks before the tabs on the top piece broke. I got mine for less than 20$ shipped. I was not to impressed and have not replaced it with another. I have taken to buying the bulk cheap ones from ebay (usually 3-5 at a time for about 10$ shipped. They last for about 6 weeks each.
    03-19-2012 11:23 PM
  14. andrewsean7830's Avatar
    Thanks for distribution knowledge regarding some vital steps
    10-26-2015 02:09 AM
