Results 1 to 3 of 3
    Default Phone dosen't work from home
    My phone works every but at home, I can't make a call or send a text from home. If I'm anywhere else it works fine. I can't seem to be able talk to the tower, if i use the open signal app it sees the tower and acts like I'm connected.
    I'm running CM 7.1.0 speedy, I updated to 7.2 but had issues so i downgraded but that was weeks ago and it worked fine afterdown grageding.
    It stopped working on 7-4, I live in the detorit area.
    anybody run in to this before or know how to fix it???
    Attached Thumbnails Attached Thumbnails Phone dosen't work from home-screenshot-1341850981225.png
  2. #2
    Default Re: Phone dosen't work from home
    Quote Originally Posted by buddha112572 View Post
    Two things I would suggest, one: you're not running the most current radio (1.08.01.0111) available here
    and two: have you tried updating your PRL? You'll need to be on a Sense-based ROM in order to do so, so: make a nandroid backup, wipe, flash Sense ROM, Settings>System Updates>Update PRL (I think the latest is 60690), restore nandroid backup (the PRL should stick).
    Not sure if these will solve you're issue but they're a place to start!
    upgraded the radio, still no luck, flashed back to the stock ROM and still not working after updating the PRL. Called Sprint and the tech had me go though a bunch of resets and reprogramming. He still could not get it to work.
    He said there was a issue at thee tower and they were working on it. He finally gave me a $15 credit on the account.
    Is there a way to make you phone connect to a different tower?
B
