Results 1 to 7 of 7
- 02-20-2011, 09:12 AM
Thread Author #1
[Guide] All About Rooting the HTC Shift: FAQ's & How To's (Updated 3/28/11)
Thanked by 4: - 02-20-2011, 09:13 AM
Thread Author #2
FAQ
Q: What is Root?
A: Root, is super user access of your phones operating system. Think of your phone as a desktop computer. Right now you are logged on as a guest account. you can browse things and use applications but if you really want to change anything in your system you can't. What gaining root does is it gives you superuser permission to alter files that you could not before; again thinking of it as a computer you now have an Administrator account.
Q:Does rooting void my warranty?
A:Yes and no. If you walk into your carriers store with a phone that has Root access and they actually check it they have the right to say this phone was tampered with. But for those of you in the know, there are methods to unroot your phone first.
Q: Does rooting slow down my phone or drain battery.
A: NO, root is not an application or a running process, gaining root does not do anything but give you permissions that you normally would not have. Basically all you did during the rooting process was move files around. Its what you do with this new found permission that changes things. But as far as just rooting it does not make a difference.
Q: Will I lose any apps or data during the rooting process?
A: No, for the same reason as above. Rooting is basically just moving some files around. Of course there is always a risk of something happening in any process. I would say chances are of causing serious problems is slim to non. Its what you do with this new found permission that changes things. But as far as just rooting it does not make a difference.
Q: I lost root during an update, am i doomed?
A: No, what happend was the file containing your super user access was over written. Just re-attempt gaining root and you will be fine.Last edited by Big D5; 02-20-2011 at 10:00 AM.
Thanked by 4: - 02-20-2011, 09:18 AM
Thread Author #3
Temp Root your EVO Shift
I am writing this to kill some of the myths and to help those who want temporary root access until a permanent root is available. (Permanint root is now available) As far as I can tell this is completely reversible with a battery pull. With that in mind you must understand that you are rooting your phone and anything can happen. I am not responsible for anything that happens to your EVO Shift 4G you are doing this at your own risk. Do you understand this? Read it again... Now lets get thet temp root so we can start using those great root apps.
First what you need:
1) Astro file manager or the file manager of your choice (available in Android Market)
2) Visionary (attached to this post) Thanks to PaulOBrien for this great app.
Install Astro File Manager if you don't already have a file manager. Now go to Menu>Settings> applications and check the box for unknown sources. Now go to Menu>Settings>Applications>Development>put a check in the box for USB debug. Use Astro file manager or the file manager of your choice to navigate to Visionary run the apk. Go to your app drawer look for Visionary open it and chose temp root let it run once complete you have temp root if it fails (stalls on black screen) hit the back button or home open Visionary again and chose temp root again.
Hope this helps,
DaveLast edited by Big D5; 03-05-2011 at 07:36 PM.
- 02-20-2011, 09:28 AM
Thread Author #4
Beginner's Guide to Installing the SDK and ADB (Updated 3/5/11)
Originaly posted by brandokc HERE All thanks to you for posting this.
I posted this up over at XDA. I'm putting it up here by request.
I hope it helps!
It looks like we may have some users that are new to rooting or to Android all together.
I posted these instructions in the perm root thread, but I figured putting them in their own thread would make it easier to find.
This is meant as a basic pre-cursor to following BCNice's perm root instructions.
This is optional you don't need to do this if you use the flash able recovery in post#6
I've added a link to TrueBlue_Drew's adb/fastboot guide
If you use the method that I outline below just download his zip and extract the files to your desktop. Then move the fastboot file into your AndroidSDK\platform-tools sub directory. Thanks to Drew for putting together a great guide!
You will need fastboot installed to install BCNice20's recovery.img.
__________________________________________________________________
Make sure you have HTC Sync installed on your computer
First download the SDK
Make sure to dowload the installer_r09-windows.exe I tested and r10 works fine
Now install the SDK when prompted for the install path paste C:\AndroidSDK over the default path
If you are having Java issues download the JDK Version 6 from Then run the SDK installer again.
Once you have installed it open it from the start menu
Select install packages
The main one we are concerned with is "Platform Tools"
You can reject all the other packages they are not needed for this process.
Go to the start menu and right click on My Computer in XP Computer in Windows 7.
Select properties, then select advanced/advanced system settings in Windows 7, then environment variables, now go to the lower box (system variables) and select path then edit.
Paste the following as your path C:\AndroidSDK\platform-tools then select o.k.
Make sure you have temp root via Visionary or Z4.
On your phone go to Settings, Applications, Development, and make sure USB Debugging is checked.
Now connect your phone to your computer and leave the connection type as "charge only"
On your computer select Start, then run, type in CMD
Once in the Command Prompt enterThe next line should pop up C:\AndroidSDK\platform-tools>Code:cd C:\AndroidSDK\platform-tools
Now test adb by typing inIf adb runs you are ready to start!Code:adb
TypeThen typeCode:adb shell
Allow Superuser on your phoneCode:SU
You are now in and ready to follow BCNice's directionsLast edited by Big D5; 03-29-2011 at 06:16 PM.
Thanked by 3: - 02-20-2011, 09:32 AM
Thread Author #5
Permanent Root Detailed Instructions
All thanks for this guide go to brandokc and bcnice. Originally posted HERE
This is a little more in depth guide for those that want to root their Evo Shift.
This is based off of BCNice20's guide, work, and instructions posted on XDA
I take no credit whatsoever for obtaining root or anything development related.
I simply took BCNice20's instructions and added more detail for less experienced users. In fact much is simply copied over.
I take absolutely no responsibility for your phone if you brick it, if it melts, if it sleeps with your wife, or if it burns your house down.
Proceed at your own risk.
Step 1
Temp root your device using Visionary or Z4 (I prefer Visionary) (Temp Root Guide available HERE)
If you are already temp rooted skip this step
Step 2
Download the file linked at this address
Extract the contents to the root of your SD card.
If you are having trouble extracting download
Once installed connect your phone to your computer as a disk drive
right click on the shift-root.zip, select extract here, then use the dropdown to locate your device, more specifically your SD card
Once you have extracted the file to the root of your sd card change your connection type back to charge only
Step 3
If you have followed my other thread (Available HERE) you already have adb working
Open the cmd prompt and paste the followinghit enterCode:cd C:\AndroidSDK\platform-tools
typehit enterCode:adb shell
you will see thisno typeCode:$
hit enterCode:su
Superuser will prompt you to click allow on your phone. Click it quickly to allow permissions!
Now you will seeyou have root permissions.Code:#
Step 4
Verifying md5sum
Make sure you copy and paste this exactlythen hit enterCode:md5sum /sdcard/Shift/hboot_orig.bin
Your result should look like this 386c19451e8dd18f9b98fad6b11be4c0 hboot_orig.bin make sure the numbers match. You may have some extra path in front of hboot_orig.bin.
Next copy and paste this exactlythen hit enterCode:md5sum /sdcard/Shift/hboot_eng.nb0
Your result should look like this 60ec1006e6ec2e8acb370d6aad35b17e hboot_eng.nb0 make sure the numbers match. You may have some extra path in front of hboot_eng.nbo.
If these do not match do not proceed. Delete the file placed on the root of your sd card and repeat step 2 and redownload.
Step 5
Now we're going to flash the eng spl. This is where the unpleasant things can happen.
Make sure you are in adb shell with superuser(root) permission. This was explained in Step 3.
If you are not in adb shell with root permissions then do not proceed. Do not pass go, do not collect $200.
Now DO NOT REBOOT until you are instructed to do so!!
Now paste this exactly into cmd promptand hit enterCode:dd if=/sdcard/Shift/hboot_eng.nb0 of=/dev/block/mmcblk0p18
You have flashed the eng spl. Now we will make sure it flashed properly.
Step 6
Check the md5 of new flash hboot and restore if necessary
run this command to pull the newly flashed hboot to your sdcard
type
in the command prompt and hit enterCode:dd if=/dev/block/mmcblk0p18 of=/sdcard/Shift/hboot_check.nb0
now we check the md5 to see if it matches
Enterin the command prompt and hit enterCode:md5sum /sdcard/Shift/hboot_check.nb0
it should read 60ec1006e6ec2e8acb370d6aad35b17e
if the md5sum matches then congratulations its safe to reboot!! you can skip the next bit and continue on to step 7
if you absolutely cannot get the eng hboot to flash right then run this to restore the stock hboot
Typein the command prompt and hit enterCode:dd if=/sdcard/Shift/hboot_orig.bin of=/dev/block/mmcblk0p18
then pull it to check md5
Typein the command prompt and hit enterCode:dd if=/dev/block/mmcblk0p18 of=/sdcard/Shift/hboot_check1.bin
then check the md5sum
Typein the cmd prompt then hit enterCode:md5sum /sdcard/Shift/hboot_check1.bin
it should read 386c19451e8dd18f9b98fad6b11be4c0
if it doesnt keep trying until it does but DO NOT!! reboot till it matches
Step 7
check hboot and perm root!!
ok now reboot your phone into bootloader
turn off phone and hold power+vol down till it boots into bootloader
look at the top and make sure it says s off
if so reboot the phone back into android
put the phone into airplane mode
Next temp root with visionary
after you are temp rooted then attempt to perm root with visionary
your phone will reboot and you are now officially perm rooted any changes you make will now stick on rebootLast edited by Big D5; 03-29-2011 at 06:20 PM.
Thanked by 6: - 02-20-2011, 09:36 AM
Thread Author #6
How to flash recovery
New Recovery
The easiest way to load the latest Recovery is through ROM Manager. Just download ROM Manager from the Android Market once installed open ROM Manager and chose "Flash ClockworkMod Recovery. Once complete boot in to recovery and make a backup this new recovery will back up the WiMax keys and everything.
OLD___________________________________________OLD_________________________________________________OLD
Recovery
for now this recovery does not backup your wimax keys
we shall do that manually and store them in a safe place just in case because you never know what can happen. Now open the root shell (Guide HERE) make sure you have supper user access and are showing the #
Backup Wimax Partitions
Code:dd if=/dev/block/mmcblk0p25 of=/sdcard/Shift/wimax.bin
Now that fells better doesnt it just knowing you wont loose 4G forever should take some pressure off.Code:dd if=/dev/block/mmcblk0p30 of=/sdcard/Shift/udata_wimax.bin
Step 1
Now download this file and move it to the root of your SD card
File originally posted
Step 2
Unplug your Shift from your PC and turn the power off
Step 3
Hold down the Volume down button and power on your shift will find the file and flash the recovery just chose yes when prompted then reboot.
Step 4
Once rebooted plug your Shift back in to your PC chose disk drive then remove the Zip file from your SD card unplug from your PC
Step 5
Lets check out that recovery and put it to some good use. Power off your shift. Now hold the Volume down button and power on. Use the up and down volume buttons to chose recovery from the list (Left & Right on keyboard work as well) press the power button (or enter on the keyboard) You will be taken to the Clockworks recovery screen. Now make a Nandroid backup just in case.
Thats it happy flashing,
DaveLast edited by Big D5; 03-29-2011 at 06:21 PM.
Thanked by 6: - 02-20-2011, 09:38 AM
Thread Author #7
Thanked by 14:+ Show/Hide list of the thanked
