Android Forums at AndroidCentral.com >  Sprint HTC EVO Forums >  HTC EVO Shift 4G > Youtube Problems on Evo Shift
Reply
Thread Tools Search this Thread
    Thread Author   #1
Old 01-27-2011, 10:20 PM
Device(s): OG Evo
ROM/Kernel: CM7/AOKP
Theme: Whatever works
My Next Device: GNex/E4GLTE
Activity: 0/20
What's up, forum?
Well my wife purchased an Evo Shift recently and, while she absolutely *LOVES* it, she is quite upset with the youtube app. We've tried to get it to work, including wiping the cache, and even tried re-installing the update, but she is unable to stream video on it.
Anyone else have this problem? Or is this most likely an isolated issue?
  #2
Old 01-27-2011, 11:27 PM
Device(s): EVO Shift
Activity: 1/20
No problems here. Every time I've pulled it up it has worked flawlessly.
  #3
Old 01-28-2011, 08:46 AM
Device(s): Shift 4G
ROM/Kernel: Shift Deck 1.xx
Theme: Embossed
Activity: 0/20
I sometimes get streaming errors when i try to view youtube videos through my fb app. But using the actuall youtube app works fine on my device.
  #4
Old 01-28-2011, 10:05 AM
Device(s): HTC EVO Shift 4g/HTC Hero
ROM/Kernel: Stock 2.2/CM6.1.0-Heroc
Activity: 0/20
i too am constantly getting video errors when trying to use the youtube app...i even uninstalled the updates and still get errors...it is quite annoying, but im used to it as ive never seen the youtube app work well on my hero either...maybe theres another new update that fixed it will have to check
  #5
Old 01-28-2011, 02:04 PM
Device(s): HTC EVO Shift 4G
Activity: 0/20
Quote:
This is true for me also.
Edit:
To add information in light of later posts: I do not have 4G available in my area, but the YouTube app runs nicely on both 3G and WiFi.
  #6
Old 01-28-2011, 02:57 PM
Activity: 2/20
Me too
  #7
Old 01-28-2011, 04:31 PM
Activity: 0/20
I often have problems on the 4G network after using the YouTube app for 30-60 minutes. I don't think I've had any problems with it on 3G. I should have tried turning the phone off and on, but it always happens after midnight...
  #8
Old 01-28-2011, 04:53 PM
GHB GHB is offline
Device(s): HTC EVO 3D & HTC Flyer
Activity: 1/20
Only time Iv'e had an error message trying to use YouTube is when I'm in a weak signal area. But with a strong signal or wi-fi I have no issues.
  #9
Old 01-28-2011, 05:55 PM
Device(s): HTC Shift, Sony S
Activity: 0/20
Quote:
This might be the trick.
Are you having issues with the app itself or streaming the video? If it is the app, you can try other apps that might work better: [Only registered users can view links. ]
While not watching a lot of youtube vids, I have noticed that watching them at home is much better than watching them at work. The main difference I can tell is signal strength.
  #10
Old 01-28-2011, 09:00 PM
Device(s): EVO Shift 4G
ROM/Kernel: cyanogen_speedy-toastcfh
Theme: Not needed
Activity: 1/20
I have the same issue with the app try viewing the videos in the browser just make sure you have mobile view turned off when watching you tube videos. This is a you tube issue not an issue with the device this issue has been reported on other device.
Cool,
Dave
Thanked by mattchew86
