1. B-San's Avatar
    I've had my Shift for almost a month and love it - unfortunately the only problem I've discovered with it seems to only have one solution: exchanging for a new Shift... Here is the original thread: http://forum.androidcentral.com/htc-...d-problem.html
    I went back to the Sprint store yesterday & they offered to replace it without hesitation, but before I go ahead with the exchange - I'm would like to back up all my data.. SMS, Contacts, Apps, ect..
    So far I've gotten these apps from the marketplace: Backup Everything, SMS Backup & Restore, and SMS Backup +.. I've also backed up my contacts to my 16 gig Micro SD card & google & copied all data to a computer...
    I'll simply insert the Micro SD card in the replacement phone...
    Any feedback on these apps or recommendations of others that may best serve me in my quest to backup & restore all my stuff?
    Oh yeah - lastly I must add that due to being a complete Android noob, I would rather not root my phone at the moment...
    Thanks in advance!
    02-28-2011 05:14 PM
  2. crump84's Avatar
    Here is a good thread on how to backup everything on your Android. Back-up (Almost) Everything Before RUU/Factory Reset - Android Forums I would assume the same principle applies for changing to a new device
    02-28-2011 05:50 PM
  3. Ntchwaidumela's Avatar
    The tech at your Sprint store should be able to transfer all your info to the new phone. But I would back up your apps separately to your SD card, just in case.
    02-28-2011 08:34 PM
  4. B-San's Avatar
    Thank you both... that link was super helpful!!
    03-02-2011 02:55 AM
  5. crump84's Avatar
    Glad I could help. Good luck with your new device
    03-02-2011 07:16 AM
  6. stillryan's Avatar
    Unfortunately the techs can only transfer your contacts from the old phone to the new one. I know because I was a tech at sprint for a little over 5 years. If you use app brain you can back up a list of apps and redownload them easily from the market, and its free. I've used sms backup and it worked fine too.
    Sent from my Shift using Tapatalk
    Ntchwaidumela likes this.
    03-03-2011 12:56 AM
  7. B-San's Avatar
    Exchanged my phone; Appbrain & SMS Backup did the trick... thanks again everybody!!
    03-03-2011 05:07 PM
  8. Deranged Cat's Avatar
    i just recently moved all of my contacts to gmail so they could sync with Android phones. as for SMS, i use google voice which also gets restored when i get a new phone. for SMS to my real number, i use SMS backup (gets sent to my gmail). Otherwise, everything else is on my SD Card.
    The only thing that annoys me about getting a replacement phone is that i have to set up all my icons and such.
    03-05-2011 07:24 PM
  9. crump84's Avatar
    Went through the same thing with my replacement device.. but it's worth it to have a phone that works!
    03-05-2011 07:34 PM
