Results 1 to 17 of 17
- 03-03-2011, 01:01 PM
Thread Author #1
- 03-03-2011, 01:37 PM #2
- 03-03-2011, 02:17 PM #3
Awesome idea.
With all the extra wiring inside the device now, have you seen a difference in your reception good or bad? - 03-03-2011, 02:32 PM #4
- 03-03-2011, 02:54 PM
Thread Author #5
HTC EVO 4G - 03-03-2011, 05:29 PM #6
- 03-03-2011, 06:21 PM #7
- 03-03-2011, 08:44 PM #8
Good work! I'm going to try this with my Fascinate. I'm pessimistic of fitting the chip after judging the snugness of the battery cover but we'll see. I guess I could file away a bit of the cover.
My buddy in security gave me a couple blank cards to practice with. To melt the credit card style badges, I've used simple nail polish remover. Let it sit submerged until the card's shape deforms and simply pull the layers apart. - 03-03-2011, 09:07 PM #9
Slick... I like the concept.
- 03-03-2011, 11:45 PM
Thread Author #10
Not yet. I justbgot e phone a couple of days ago. I don't own any yet but I'll report back when I do.
I work very closely in the Security Department at my job. They gave me 5 old beat up badges to test this out on when I originally did this to my Pre. I'm really happy it worked. I hate caring around the ID card (I do get yelled at a lot for not having it though).
Thanks for all the comments and feedback! This forum rocks.HTC EVO 4G - 03-04-2011, 12:58 PM #11
I did this yesterday with my access badge. I was surprised that the chip was tiny. It's about the size of a rice grain cut in half. I had to be very delicate because 2 copper strands went to the chip.
It looks good retrofitted into my HTC Evil.
I had ordered a secondary Chase debit card so I can get bonus Continental miles and I will be hacking that apart and retrofitting it into my phone since it has Blink/Pay Pass built in.
Do you guys think the 2 chips will interfere with each other? - 03-04-2011, 11:52 PM
Thread Author #12
I don't think so but it is possible. The chips in the cards are dormant until they receive a specific signal from the card reader they are programmer to. Only then will the chip transmit it's signal (card number, acct number, ect) back to the reader. With two cards installed, they should both stay dormant and not interfere with each other (unless they use the same activation signal). The same activation signal is very unlikely. Happy modding.
HTC EVO 4G - 03-05-2011, 07:22 PM #13
- 04-20-2011, 05:22 PM #14
Found this thread last night. Well, guess what happened today? Locked out
, had to have security let me in (luck have it knew him). So got home and immediately did this mod
. I never forget my phone. Have forgotten my card enough to be on a first name basis with most of security. But not anymore
Thanks for coming up with this.
- 05-19-2011, 09:59 AM #15
- 05-19-2011, 11:16 PM
Thread Author #16
Awesome. Let me know how it goes. Hit the QR code up if you have any questions.
HTC EVO 4G - 01-05-2012, 10:07 AM #17
Re: RFID Battery Cover for Evo SHift 4G
Thank you for this amazing share!
I am trying to do the exact same thing, as finding this thread was almost my last attempt to get more information on how to do it.
I came here through
However my problem is much more serious; my RFID chip is about 1mm tiny! look at the picture:
As you can see, the chip is very tiny, and this is my second attempt already with Acetone!
On first attempt I did not even find the chip (didn't expect it that small).
Second attempt in the picture, I already caught it although too late as it was torn off the wire.
Next week I will be trying a third card
Meanwhile, any suggestions? How long should I leave it submerged in the Acetone?
As last resort, I am also thinking to simply carefully trim the edges of the card, then peel off layers of plastic (without using any Acetone), until it would fit in the cover of my Samsung Galaxy Note.
However, another idea I am pursuing is the use of NFC - I think this phone has NFC in it, so theoretically it should be able to emulate any RFID card, no?
Reply
