Results 1 to 5 of 5
    djrakowski's Avatar
    Posts
    Global Posts
    276 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Flyer won't power up
    I placed the device on its charger last night, and the green light was on, indicating a full charge. But I can't power up the device regardless of what I do.
    And last night, I attempted to download a few apps from the market. Each time, it indicated an in-process download, but quit within seconds, and the apps didn't show up on the device.
    Any ideas? I'll probably return it and get an Iconia instead. I like the smaller form factor, though, and have even thought of getting another Galaxy Tab or waiting for the release of the 8.9" model.
  2. #2
    S Prime's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by djrakowski View Post
    Try HTC Support. Open 6:00 am- 1:00 am EDT 7 days a week. 866-449-8358. My guees is that they will have you pull the battery. Let us know.
  3. #3
    caledonian's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Press and hold the power button for 20 seconds.
    I had the same issue, and called HTC support. The guy told me that the power off is akin to hibernating on a PC, and suggested a restart at least once a week will help keep the device 'stable'. Restart is the equivalent of powering down and pulling the battery in other Android devices and then powering up again.
  4. #4
    Wobblin30's Avatar
    Posts
    Global Posts
    477 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Try booting into recovery and doing a factory reset:
    Hold the Volume Down button
    Press the Power button until the device turns on
    Select Factory Reset by pressing the Volume Down button
    Press and release the Power button
  5. #5
    Trace Mc D's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy Re: Flyer won't power up
    Wobblin30
    I have tried this it doesnt power on but it does have a quick short red light flashing once then does nothing any other ideas as to what I can try to get my HTC Flyer working again ?
