1. oceanbeat's Avatar
    Does anyone have input regarding the htc power saver vs the snapdragon battery guru?
    05-12-2013 09:02 PM
  2. meyerweb#CB's Avatar
    When the snapdragon app first came out, several people in the S3 forums tried it and didn't find it particularly useful. I don't know what the htc power saver feature does.
    abubadr likes this.
    05-12-2013 09:13 PM
  3. bigtnew's Avatar
    Guru was constantly screwing up my WiFi. Turning it on or off at all the wrong times. I didn't find the battery life to be much better with guru either. I still use juice defender ultimate occasionally and find that works better for my needs.
    05-12-2013 09:56 PM
  4. Fraslin#AC's Avatar
    I have been running both for 2 weeks or so and been very happy. Don't even notice they are running (except in the sun, the dimmer display is hard to read so I turn off battery saver). Don't notice any performance hits. Not using it for video but am a pretty heavy user otherwise with email, podcasts, app usage, etc.
    05-12-2013 09:58 PM
  5. KoukiFC3S's Avatar
    I'm getting great results with battery guru.
    Lost about 5% overnight.
    05-13-2013 12:31 AM
  6. Russ Smith's Avatar
    You can disable the WiFi option
    Sent from my HTC One
    05-13-2013 01:13 AM
  7. el bos's Avatar
    I'm getting great results with Battery Saver and Snapdragon Battery Guru. I recommend these settings...
    Attached Thumbnails Power saver vs Snapdragon battery guru?-screenshot_2013-05-13-13-43-59.jpg   Power saver vs Snapdragon battery guru?-screenshot_2013-05-13-13-43-28.jpg
    05-13-2013 03:53 PM
  8. Ichwardort's Avatar
    The app description tells me it's for all Snapdragon devices. Well my "HTC One X" is powered by a snapdragon, but still the play store won't let me install the app???
    07-08-2014 08:01 AM
  1. Nexus 4: has anyone downloaded snapdragon battery guru?
    By mattatwar1 in forum Google Nexus 4
    Last Post: 03-19-2014, 07:40 PM
  2. Snapdragon Battery Guru App
    By qbngator in forum Sprint Galaxy S III
    Last Post: 02-26-2013, 08:47 AM
  3. Battery time not always accurate/ and power saver
    By russel5150 in forum Verizon Galaxy Note 2
    Last Post: 02-22-2013, 06:39 PM
  4. (stock) Power Saver and (app) Battery Saver?
    By puddin78 in forum AT&T Galaxy S II
    Last Post: 03-10-2012, 09:26 PM
  5. Power Off vs Battery Pull
    By estebanj in forum AT&T Samsung Infuse
    Last Post: 07-29-2011, 07:27 PM
