Results 1 to 4 of 4
    Default M8 Battery vs Droid Maxx Battery
    I'm considering the M8 because of the build quality and I like GUI that r close to stock android as possible. I currently have the droid Maxx but I travel a lot and run out of storage when I download movies and music files. I keep them on my phone so I can watch them in airplane mode. My concern with the M8 is the battery compared to the Maxx. The Maxx better would last me two days on a single charge with energy to spare.
    To the people currently using the M8 ... How is the battery life?
  2. #2
    Default Re: M8 Battery vs Droid Maxx Battery
    For adding memory to your Maxx, try a Meenova or similar device. It is a usb-otg that has a slot for a micro sd card and plugs into the phone. However, with kit Kat you will need some app downloads to make it work. Do a Google search for 4.4 breaks usb-otg.
    The Meenova is only $12 and the size of a quarter will hold 64gb of media.
    http://www.meenova.com/st/p/m3r.html
    Also a nice add for your Maxx is a Tylt Vu wireless charger. No noise, no heat, no positional worry... Just works great.
    Sent from my GT-P6210 using Tapatalk
  3. #3
    Coming from the older Maxx HD, if you were getting 2 days out of your Maxx, you're going to get just over a day with this phone. My suggestion is that you plug it in at night. That's all. Carry a charger with you when you travel and plug it in beside the hotel bed and you'll be fine.
  4. #4
    NicksGarage's Avatar
    Posts
    Global Posts
    996 Global Posts
    Carrier
    Stock
    You could always get an external battery to extend the life. I use a small 8000mah one when I go camping.
    Sent from my HTC One M8 via Tapatalk 4 Pro
  1. Replies: 30
    Last Post: 05-11-2016, 03:34 AM
  2. Amazed by the battery...
    By bucketheadmn in forum HTC One M8
    Last Post: 04-26-2014, 04:32 PM
  3. HTC One (M8): Hiding home menu buttons
    By RRHMJ23 in forum HTC One M8
    Last Post: 04-14-2014, 10:42 AM
  4. HTC One (M8): new onscreen buttons problems
    By Ledward1245 in forum HTC One M8
    Last Post: 04-14-2014, 09:50 AM
  5. Got two weeks battery life on my note 12.2
    By thegame161 in forum Samsung Galaxy Note Pro 12.2
    Last Post: 04-14-2014, 03:35 AM
