Results 1 to 17 of 17
    Default Does your extreme power saving mode really work?
    Today, I turned on my extreme power saver mode. I turned it on at 1 p.m at about 11% and at 3 o'clock it was down to 4% . That doesn't really seem like any kind of power saving to me. Is anyone getting better results than that? can you chime in and let me know? I burned up 7 percent in 2 hours, and I wasnt using the phone. Hell, I think I might've used less power had I not done anything!!
  2. #2
    Default Re: Does your extreme power saving mode really work?
    That doesn't sound any good at all... Can't try it yet on my att phone...
    Sent from my HTC One_M8 using Tapatalk
  3. #3
    Mine seemed to help significantly the couple times I've used it, not up to the 15 or so promised hours though if I actually used it. Maybe in standby
    Sent from my 831C using AC Forums mobile app
  4. #4
    ChrisGonzales90's Avatar
    Posts
    Global Posts
    1,647 Global Posts
    Carrier
    None
    Mine works fine
    are you using extreme power saving mode or perhaps just the standard power saving mode? Extreme power saving mode turns your phone in to a basic, flip phone like experience while the standard power saving mode, reduces CPU usage and screen brightness, plus a few other things but you can use the phone as normal, and data can still be used as EPSM it turns off all data)
    Sounds like you used the standard power saving mode
  5. #5
    Quote Originally Posted by CHILLYWILL_95831 View Post
    i thought most of the US still have not gotten the extreme power saver mode update yet
    It s definitely extreme power mode and that's not the first time I got shifty results
    Quote Originally Posted by jackoceanz View Post
    We've got it on Sprint! Supposedly!
  8. #8
    Anyone know when the update for this is coming to Verizon?
  9. #9
    Posts
    Global Posts
    1,647 Global Posts
    Carrier
    None
    Sprint is the only US carrier who has it.
    Posted via Android Central App on the HTC One M8
  10. #10
    I don't have it on my unlocked US version
  11. #11
    Me Too! Im almost glad its not just me lol. I turned on Extreme Power Saving Mode and it burned 7% in 3 hours. Thats pretty fast for an extreme power saving mode on stanby.
    One thing I did notice tho, my LTE data was still on. I thought all the while that it would automatically cut data, bluetooth etc. But seeing Email is one of the apps it allows then maybe thats why it doesnt cut it off.
    My next try will be to shut down data, lower screen brightness, shut down bluetooth and see how many hours 10% would take me while on EPS and hardly touching the phone. Maybe others can do the same test. lets keep it at 10% so as to keep variables the same.
  12. #12
    To further add to this, I just read the LEARN MORE in EPS Settings, and it does say that EPS mode will turn off data when the screen is off. However, when I quickly open the dot view case, and screen turns on, I can clearly see that LTE is still connected. Usually when data is off and if it is supposed to turn on when the screen comes on, it will take 1 or 2 seconds to connect. So I dont know if it really is off and the LTE sign mistakenly shows it as being ON, or they missed this and LTE is actually still on. Can you guys check yours?
  13. #13
    It only has an effect on standby time really. If you're still texting and calling and emailing it'll drain the battery still.
  14. #14
    My 10% on EPS lasted 4 1/2 hours. LTE was on the whole time (i dont know if it turned it off on its own but whenever I turn screen on it showed as connected)
  15. #15
    Quote Originally Posted by hdradaza View Post
    Are you guys sure you're in extreme power saving mode?
    Does your screen look like the first picture on the following page? If not, you're not in extreme power saving mode.
    Using Extreme Power Saving Mode on the HTC One M8 | Android Central
  16. #16
    Yes i know what extreme power saving mode is.... 200 percent sure
  17. #17
    I have a T-Mobile M8, I've only had one experience with EPSM. I left my charger home and my phone had fallen to about 23% so I activated it at about 8:30pm and at about 7am it was on 21%. So mine works perfect
    James E1 likes this.
  1. Camera360 save path to external SDcard problem
    By XiiDevil Nz in forum Samsung Galaxy Note 3
    Last Post: 08-24-2014, 07:18 PM
  2. apps stop working for second user
    By The doomed in forum Samsung Galaxy Tab Pro 10.1
    Last Post: 07-06-2014, 07:51 AM
  3. When and how do you charge your M8?
    By Kram007 in forum HTC One M8
    Last Post: 05-17-2014, 11:10 AM
  4. Quiet Mode override...
    By Sincs in forum LG G2
    Last Post: 05-01-2014, 12:12 PM
  5. What does consume more battery?
    By Omer San Gabriel in forum Samsung Galaxy S4
    Last Post: 04-30-2014, 02:16 PM
