extreme camera lag with low shutter speed
jam3s121
17
anyone else notice this? my phone completely locks up when the shutter is set to a low speed.. i mean i'll probably never use it but kinda odd.
Skyway
1,157
You mean high shutter speed right? For night time shots? Explain exactly what you're doing because when you set shutter speeds higher, more light is let in and will be extremely delayed. All camera's will do this
jam3s121
17
I mean high shutter speed. When the speed is set to below 0.5 as in 1second or higher speeds the cameras preview is completely lagged out, it is not fluid or responsive until i put a faster shutter speed on.
I understand that the longer you set the shutter the longer it stays open which means the photo takes longer to actually take, i'm taking about the preview screen being completely unresponsive
Skyway
1,157
Yea that's normal. Every camera I've ever used is the same way. The shutter is being held open for whatever time you specify, so if you set it to 4, then there will be a 4 second delay to allow more light to hit the sensor. If you have steady hands and a static subject, you can get some great nighttime/low light results
jam3s121
17
I dont think you understand, I set the camera shutter to 4 seconds and my phones screen locks up without taking a picture, i can't set focus or do anything.. there is no preview before i take a picture. I understand what shutter speed does when you take the actual photo but this is before im even taknig a photo
mchockeyvette27
1,539
How do you even set the camera shutter speed?
Sent from my HTC One_M8 using Tapatalk
ChrisGonzales90
307
4
Try resetting the camera settings. See if it fixes it.
Posted via Android Central App on the HTC One M8
whitelunchbag
567
It's not broken!
It's a live preview of what a 4sec exposure time will look like.
If you move the lens, it will go blurry.
Hold it still for 4 seconds and it'll be fine
Posted by my Nexus 7 (2013)
twin100
Active member
Nov 27, 2012
40
This section might be hidden on some phones, but it’s very easy to access. On many phones, you just have to open a certain page in the settings and tap a button seven times. Use Google to figure out how to enable Developer options on your phone if it’s currently hidden (for example, search “enable developer options HTC One”).
Once you have access to Developer options, simply scroll until you find the following three settings, which may be located on the main screen or within an “Advanced” subsection:
Window animation scale
Transition animation scale
Animator animation scale
Tapping each of the three aforementioned settings will reveal that it’s set to “1x” by default. If you want to speed up your phone or tablet dramatically, simply change each of those three settings to “.5x” — that’s it.
B0WIE
1,025
It's not broken!
THIS^^!! To grab more light it must stay open and take a longer sample. They could display it different but it's not broken.
Skyway
1,157
This section might be hidden on some phones, but it?s very easy to access. On many phones, you just have to open a certain page in the settings and tap a button seven times. Use Google to figure out how to enable Developer options on your phone if it?s currently hidden (for example, search ?enable developer options HTC One?).
Once you have access to Developer options, simply scroll until you find the following three settings, which may be located on the main screen or within an ?Advanced? subsection:
Tapping each of the three aforementioned settings will reveal that it?s set to ?1x? by default. If you want to speed up your phone or tablet dramatically, simply change each of those three settings to ?.5x? ? that?s it.
It has absolutely nothing to do with animation speed. Your post is completely irrelevant to this topic
