1. pendraggon87's Avatar
    I use Hangouts for SMS and IM, and I use gmail, etc. When I have new mail, or FB messages, or anything, i do not see any notification light.
    05-22-2014 01:41 PM
  2. dty06's Avatar
    There's been a reported issue with the notification LED only being on for 5 minutes. Try sending yourself an email or text message and see if the light comes on at all.
    05-22-2014 02:39 PM
  3. Mooncatt's Avatar
    I can't speak from experience because I don't have the M8, but I've been reading up a lot on it here and there's a thread addressing it. From what I can tell, the t minute flash is an HTC thing hard set in the phone. There is a definite issue with it not flashing the LED at all too. There seems to be two ways around it.
    The easiest is people are reporting to disable the Verizon Messenger app. That one wasn't well reported on either way, but several people that tried said that fixed it. Worth a shot first. The other is to factory reset and skip the automatic data/backup restores. Don't even sign into Google on the setup. After the phone finishes initializing the native apps, then manually download your other apps and such. A pain I know, but that was the more popular method and worked.
    05-22-2014 05:24 PM
  1. Verizon KitKat update causing frequent dropped calls?
    By runamuck0870 in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-31-2015, 07:52 PM
  2. My Android 4.3 out of a sudden will not charge unless it's turned off!
    By Dona Juanita in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-29-2014, 01:30 AM
  3. Replies: 3
    Last Post: 05-25-2014, 07:26 AM
  4. Low Battery LED Light
    By sparko24 in forum Droid RAZR MAXX HD
    Last Post: 05-22-2014, 12:32 PM
  5. KitKat for Verizon S3 Mini
    By elisamjfox in forum Samsung Galaxy S3 Mini
    Last Post: 05-22-2014, 11:58 AM
