1. TJGEsq's Avatar
    Last night I went to sleep with my battery at about 10%. When I woke up, my phone was dead. Here's what I don't get:
    I have the phone set up to enter Extreme Power Saving Mode at 5%. Aren't you supposed to get several hours of use at that point? If so, how could my phone have died being that it wasn't even being used? Shouldn't the phone have entered Extreme Power Saving Mode at 5%, and then ceased any background activity that may have been draining the battery?
    07-22-2014 11:57 PM
  2. TJGEsq's Avatar
    Anybody have any thoughts? Does extreme power saving mode work for others?
    10-05-2014 08:43 PM
  3. TarekElsakka's Avatar
    I have tried Extreme Power Saving mode only once when my device was at 10% and it dropped around 2% in maybe 2 or 3 hours, so I suppose it's normal for your battery to die even with EPS on. By the way, I am not sure about the circumstances you're in and whether or not you had a charger available, but I wouldn't recommend letting the battery drop that much anyways because it's bad for it.
    10-05-2014 09:11 PM
  4. reesh11's Avatar
    When mine gets to 14% it automatically goes into power saving mode. I have not tried extreme yet but does your phone at least kick on power saving mode?
    10-05-2014 10:04 PM
  5. TJGEsq's Avatar
    Yes, regular power saving mode works when I get to 14%.
    10-14-2014 01:26 AM
  6. brodrick's Avatar
    Personally, I think Extreme Power Saving Mode is a joke
    My phone can sit on the night stand all night (6 hours?) in regular mode, and drop maybe 5%. In Extreme Power saving mode, it loses the same amount, so I really see no value in it.
    The phone is very efficient at idle.
    10-14-2014 12:59 PM
  1. Jetpack Joyride save file
    By rustronin in forum Ask a Question
    Last Post: 03-04-2015, 10:38 PM
  2. LG G3 factory charger won't work
    By jbomb11 in forum LG G3
    Last Post: 07-23-2014, 10:07 PM
  3. Chromecast will not connect
    By Grant Haswell in forum Google Chromecast
    Last Post: 07-22-2014, 11:30 PM
  4. LG 40 Optimus Extreme
    Last Post: 07-22-2014, 11:01 PM
