I just got my new One M8 a few days ago and ran into some battery draining issue.
After charging the device (second charge if to be precise), I went to sleep with 99% battery while all apps are closed, Wi-Fi is turned off and Battery Saver wasn't on.
After 6.5~ hours, the battery was at 89%. In my opinion 10% drain overnight, during standby is a lot and that's why I'm a bit concerned.
Based on some recommendations, I installed GSam Battery Monitor, please see below results.
Do the results seem fine to you? I'm not really sure how to read them.
It looks like Kernel and Android System consumes 36% which is a lot.
Do you have any idea how to decrease the consumption and what causes the Kernel and Android System to consume 36%?
On that matter, it seems like the GSam consumes 5.8%. When I close the app, does it stop monitoring and consuming power or it works in the background and keeps sucking the battery?
Thanks.
Thanks.
