I set up a pin code and now I do not want it. I go to Settings, Security, Pin Code, then enter my Pin Code, The lock screen option and the no lock screen option are both greyed out. They are not highlighted therefore I can not tick off No Lock Screen. Pattern, Pin, and Password are all still highlighted.
Is there any option to correct this problem other than a complete hard reset? I have already had to hard reset two times in the last 4 days due to other issues.
